Old 02-28-2014, 07:50 PM   #1
yellow400ex05
how do you get distributor to turn so i can advance timing manually.
I want to turn my distributor a bit to advance my timing but it seems like its locked in place, i was lightly pushing against the vacuum advance to move it and it wont budge.
yellow400ex05 is offline   Reply With Quote
Old 02-28-2014, 08:00 PM   #2
Bloodhound
Re: how do you get distributor to turn so i can advance timing manually.
Loosen the hold down bolt attached to the manifold. IIRC it's a 9/16 bolt.
Bloodhound is offline   Reply With Quote
Old 03-01-2014, 09:03 AM   #3
superwade57
What he said ^ its on the passenger side of the base of the distributor. Its easiest with a distributor wrench found at a local parts store for a couple bucks but do able with out. Remember to tighten when done. Use a timing light. Pull the vacuum line off your advance and plug it then I like to set advance to 12-14* advance initially. An about 800-1000 rpm . Everyone has a different advance number they like to use. This is just where I've had good luck with
superwade57 is offline   Reply With Quote
