Old 02-28-2014, 10:49 PM   #1
Rude Ron
Rude Ron's Avatar
aftermarket gauge bezel for lots of 2 5/8" autometers?
Hello anyone know of where to get an aftermarket gauge bezel for like 10 autometer gauges? 2- 5" in the middle and 8- 2 5/8" gauges, 4 on each side? all of the ones I have seen only have a provision for 4 on the left side, I want 4 more on the right as well,,, any ideas would be great thanks ron
Edited By Staff
"If I had all the money I've spent on Trucks, I'd spend it all on Trucks"
Rude Ron is offline   Reply With Quote
Old 03-01-2014, 03:38 AM   #2
bigblock73
yeller
bigblock73's Avatar
Re: aftermarket gauge bezel for lots of 2 5/8" autometers?
Unless you are piloting an airplane, is there really a need for 10 gauges? Seems a little over the top.
But to answer your question....I have never seen one offered.
bigblock73 is offline   Reply With Quote
Old 03-01-2014, 03:53 AM   #3
Skunksmash
Skunksmash's Avatar
If size is your concern, you don't need a different one. I've got 2 that size behind the factory bezel, looks fine. It would seem that its the same size as factory. For the number of them that you want though, I'm not sure. Perhaps use all the factory spots, then a gauge pillar? That would account for 9 gauges total. You could probably come up with a decent looking spot for the 10th.
Skunksmash is offline   Reply With Quote
Old 03-01-2014, 06:21 AM   #4
Malo83
Cruzzzn' Vet
Malo83's Avatar
One can never have enough gauges
Malo83 is offline   Reply With Quote
Old 03-01-2014, 06:59 AM   #5
andrewmp6
You can get a blank panel and drill your own holes http://www.classicdash.com/shopping/...73-1987/Blank/ or change the whole dash out http://diy4x.com/cart/index.php?rout...product_id=148
andrewmp6 is offline   Reply With Quote
Old 03-01-2014, 10:18 AM   #6
84chevyguyid
I wish I had 4 on the right side of my dash. I am building a bezel with 2 extra gauges on the right side for my cummins conversion, adding a boost and pyro gauge. I would like fuel pressure and trans temp then I would be happy.
84chevyguyid is offline   Reply With Quote
Old 03-04-2014, 12:52 AM   #7
Rude Ron
Rude Ron's Avatar
Yes sir,,,,
Edited By Staff
Old 03-04-2014, 01:00 AM   #8
Rude Ron
Rude Ron's Avatar
it is over the top,,, lol... I like lots of gauges and it will be different like most everything else on it... I can make my own bezel was hoping to save the trouble and find one someone makes already, the gauges I have are 5" Tach, Speedo, 2 5/8" oil pressure, water temp, volts, boost, vacuum, fuel pressure, fuel tank, clock
Edited By Staff
Old 03-04-2014, 01:02 AM   #9
Rude Ron
Rude Ron's Avatar
ya those are cool,,, but you see how they didn't mirror each side? so it would be hard to put 4 gauges on the right
Edited By Staff
Old 03-04-2014, 01:03 AM   #10
Rude Ron
Rude Ron's Avatar
I'm with you I want 4 on the right as well.... guess I'm gonna have to fab something myself....
Edited By Staff
