Old 03-01-2014, 02:05 PM   #1
terry b
terry b's Avatar
Look at trim rings.
What do you folks think of the trim rings? The white truck will be parted in the spring.
terry b is offline   Reply With Quote
Old 03-01-2014, 03:42 PM   #2
terry b
terry b's Avatar
Re: Look at trim rings.
No opinons. Do you all think the wheels would look better painted copper? Or no trim rings.
Old 03-01-2014, 04:30 PM   #3
KMC3420
KMC3420's Avatar
I would say no trim rings looks best, original I guess. I can't hardly see the white on the rim with the trim rings on. Might look better out in the sun though.
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 03-01-2014, 05:14 PM   #4
BugzC10
BugzC10's Avatar
I think the copper would look good. Or polish up the rings. Difficult to see the ring with the white.
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 03-01-2014, 06:17 PM   #5
Yooper truck
Yooper truck's Avatar
There is not enough contrast with the trim ring/ hubcap set up and the white rims for it to look good. The idea is good, just wrong color combination.
Yooper truck is offline   Reply With Quote
Old 03-01-2014, 06:36 PM   #6
jdw
I've always liked rings and no caps, but I think that truck would look sharp with no rings and copper bowties.
jdw is offline   Reply With Quote
Old 03-01-2014, 06:42 PM   #7
terry b
terry b's Avatar
What color do you all think would look best? Could i photo shop different colors? Hey Yooper truck where is Rudyard? The white seems kind of washed out.
Old 03-01-2014, 08:38 PM   #8
yuccales
yuccales's Avatar
I'm thinking copper with caps & rings. BTW, great looking rig!
yuccales is online now   Reply With Quote
Old 03-01-2014, 08:41 PM   #9
PowerdbyChevy79
PowerdbyChevy79's Avatar
Yea you cant really see the white...I would go with copper to contrast the trim..
PowerdbyChevy79 is offline   Reply With Quote
Old 03-01-2014, 08:49 PM   #10
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I'm a no trim ring kinda guy.
Trim rings remind me of Rallye Wheels. Not "trucky" enough. **says the man with 5 window slots on his truck**
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 03-01-2014, 09:23 PM   #11
jocko
jocko's Avatar
no rings. looks best with black tire - white wheel - PO3 cap. However, the paint or pc is probably trashed already by just installing a ring to compare. Rings trash the paint. If you're always gonna have rings, then no problema, the scratches won't show. Even if you keep rings, I'd still keep the wheels white. Matching copper too much of a departure from stock - let the black that you will eventually paint in the caps provide contrast, not the wheel. I think the PO3 caps look best bone stock on the wheel/tire combo. Gorgeous truck btw. If you didn't have the cowl hood, I'd be beggin ya to keep the wheels stock looking - BUT, you do have a slight custom look, so trim rings would be just fine if that's the direction you want to go with it.
Old 03-02-2014, 12:51 AM   #12
Sicklajoie
The Niner
Sicklajoie's Avatar
I'm not a big trim ring fan.
Even my old 99 I ditched the chrome rings and centercaps and went to just a black centercap.
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 03-02-2014, 03:48 PM   #13
terry b
terry b's Avatar
The wheels are7X16 ford. I sand blasted them and painted them white. To see what they would look like. The tires are junk. Only on there to move the truck around. I can reblast the wheels to remove scratches when i install the new tires. The wheels seem to narrow at seven inches. The wider 9.25X16.5 chevy wheels look better i think. Just not alot of choice in tires.
