03-01-2014, 02:15 PM | #1 |
Blazer spare tire carrier inside
What side is the inside spare tire carrier supposed to be on left or right? And can someone please post a few pictures of how and where its located? Thank You.
03-01-2014, 03:29 PM | #2 |
Re: Blazer spare tire carrier inside
It goes on the left. Should be four threaded nuts under the floor, making it self explanatory.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
03-01-2014, 03:37 PM | #3 |
Ok Thank you I have seen a few on the passenger side so this is why I ask. Anyone have a picture of this also. I also noticed the bolts that hold it down to the floor have a short or a low head on them. Will the bolts from a "73" work for this?
03-01-2014, 11:13 PM | #4 |
Here is a photo of mine.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
03-03-2014, 02:25 PM | #5 |
Thank you for the picture. What size spare tire can you mount on it without running into issues? I am looking at putting a 33 KM2 on it ?
03-03-2014, 05:44 PM | #6 |
Don't think a tire that big will fit if it is bolted in the stock position and without being modified. (even if the stand was mounted the slot for the tire hold down bolt wouldn't go high enough for that tall a tire). The tire on mine is only a 235 70 15. If I remember correctly, the bolts needed to fit the weld nuts on the floor are fine thread.
