03-01-2014, 08:59 PM | #1 |
5.3 swap advice/questions
i bought a 2004 5.3 and 4le60 trans yesterday, has the whole harness, no ecu, or pedal or mass air, I've already ordered the pedal, been looking into getting a ecu, and mass air sensor and air box. I'm looking for advice....looking for companies to send my harness and ecu (once i get it) to get chopped up and tuned, and any other advice as to stuff i might need, and was wondering if i can use my transfer case...i have a np208 or if i could buy a adapter and use a stock one from a 2004 chevy? this is my first swap and trying to make it as painless as possible
this is going into a 84 k10 here is what i got done today... http://67-72chevytrucks.com/vboard/s...d.php?t=618692
Sgt Dennis Heineman USMC Aviation Ordnance I.Y.A.O.Y.A.S 2001-Present 84 K10 2000 trans am ws6 2011 nissan altima 2009 Troy Built with a 42 Inch Deck My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371 |
03-02-2014, 02:40 AM | #2 |
meowMEOWmeowMEOW
Re: 5.3 swap advice/questions
With the DBW stuff, be careful that your components match. If you picked up the engine seperately from the pedal (and I hope the TAC, I didn't see it listed), then you'll want to make sure that you try to get TB+ECU+PEDAL+TAC from the same year and vehicle if you can.
I would also suggest going to a brick n mortar dyno tuner over the mail order tunes if you can. There is a definite horsepower and driveability gain, and it beat having to get the thing tuned twice....a large number of mail order tune customers end up getting a dyno tune after-the-fact.
03-02-2014, 07:53 AM | #3 |
I used WWW.lsx-harness.com
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
03-02-2014, 08:52 AM | #4 | |
03-02-2014, 08:52 AM | #5 | |
03-02-2014, 05:02 PM | #6 |
meowMEOWmeowMEOW
If the TB, TAC, Pedal and ECU arent' from the same year/vehicle, then you need to make sure they are as close as possible. Different years used different calibrations for the pedal sensors, and certain models didn't use the TAC (even though the plug on the harness might still fit, it won't be setup correctly.)
Using components too different will result in a "DBW Mismatch" error, which can show itself a handful of different ways. Anything from lack of pedal response, to no control of the pedal whatsoever.
03-02-2014, 05:07 PM | #7 | |
03-03-2014, 04:52 PM | #8 |
well i wasn't able to find a ecu and tac from the same vehicle, i did find them from the same year tho...hope it all works out
03-03-2014, 08:30 PM | #9 |
meowMEOWmeowMEOW
Was it another 04 truck/van that had a v8? If so, your fine.
03-03-2014, 09:26 PM | #10 |
i ahve no issuses with them it was good and fast and it started right up second turn of the key
03-06-2014, 08:19 AM | #11 | |
how did you do your linkage and fuel set up?
