Old 03-02-2014, 03:09 AM   #1
yellow400ex05
Question Weird issue truck accelerates faster at half throttle??
I've got a 1984 chevy c10 with a 427 bbc 780cfm quickfuel carb it runs on the rich side but I noticed while on the highway tonight that it'll accelerate much slower when you mash the pedal to the floor and when you gradually let off Til half throttle you can hear a whistle or a hiss sound sometimes and it will accelerate much faster at 3/4 throttle than full throttle. I have no cats and a fresh fuel filter as well.
yellow400ex05 is offline   Reply With Quote
Old 03-02-2014, 05:28 AM   #2
roger97338
roger97338's Avatar
Re: Weird issue truck accelerates faster at half throttle??
I've a 92 Nissan pickup with a 4-cylinder, and a 75 C-10 with a 350, both of them do that. The vehicles that I've noticed not doing that have been much more "modern" engines. (Multi-cams, distributor-less ignitions, fuel injection and such.)
I've always assumed that on pre-computer controlled motors, when you mash on the throttle, they aren't able to deal with the sudden surge in fuel suddenly pouring in. Where a newer motor with computer control will see that you want to go really fast right away, and adjust the timing as it gives the motor as much fuel as it will handle...which may not equal the amount of fuel you'd be dumping in if you had manual control of the fuel flow.
roger97338 is offline   Reply With Quote
Old 03-02-2014, 12:39 PM   #3
geezer#99
geezer#99's Avatar
THat's about normal for a mechanical secondary carb. What stall, timing curve, rear gears and tranny you got?
Old 03-02-2014, 01:04 PM   #4
yellow400ex05
I have vacuum secondaries not mechanical. i have a stock stall i believe which is like 1900 on a TH400, timing curve, somewhere around 40-45 degrees timing. I've got a magnum 282S comp camp which is .561 intake and .561 exhaust. the timing was backed off by a mechanic to 17 degrees of timing but it ran a lot rougher and choppy than it does with more timing, i didn't like it at all. So I advanced it from the vacuum advance a good bit and it feels much better, but maybe i have too much timing? i can back it off a little bit. but i dont see how it can affect my acceleration being slower at full throttle than half throttle.
and i have stock 3.08 gears
Old 03-02-2014, 01:25 PM   #5
geezer#99
geezer#99's Avatar
Have you played with the vac sec springs?
Does it ping when you floor it?
Does it kick down to second when you floor it?
What's your initial timing?
Where's your vac advance hooked to?
Old 03-02-2014, 01:40 PM   #6
yellow400ex05
no i haven't touched the secondary springs. and i dont hear any pinging when i floor it. and my kick down isn't hooked up. my vacuum advance is hooked to the line going to the top of the carb on the side not to either of the bottom two
Old 03-02-2014, 01:58 PM   #7
geezer#99
geezer#99's Avatar
Have you tried pulling it back into second and then putting pedal to the metal.
Old 03-02-2014, 02:11 PM   #8
imjeff
imjeff's Avatar
Sounds like you're dumping velocity under WOT because of low demand. You've got 3.08 gears and no kick-down so I'm assuming the rpm's were well below 2500 when you floored it. You don't have enough air velocity to make your primaries efficient. A vacuum gauge would show you where this happens. I would get the kick-down hooked up so you can use that carb.
Jeff
I know a guy who's addicted to brake fluid. He says he can stop any time.
72 K10 396
75 Cj5 MPI 350 Chev
67 Chevelle 396, 4 speed
74 FXE
08 Tahoe
imjeff is offline   Reply With Quote
Old 03-02-2014, 02:29 PM   #9
yellow400ex05
well it'll only kickdown at 45mph or less. and it wont do it everytime. it seems to be okay in 1st and 2nd gear but when it hits 3rd it'll bog way down, and when i let up from WOT it'll make a hissing or sucking sound and start to accelerate faster, then if i lay back into it sometimes it'll keep accelerating better, almost like my secondaries aren't opening. plus i cant figure out why its running so damn rich. you can see it idling black smoke. i love this truck but it runs like crap! everybody i talk to wants to set it up differently.
when i put it into 2nd and floor it it'll pull fairly decent, but still when i let back on the throttle it starts to pull harder. this truck is supposed to run like hell broke loose, but instead it runs like garbage.
Old 03-02-2014, 02:40 PM   #10
yellow400ex05
here's where my vacuum advance is hooked up now, i moved it from where the red circle was to the left vacuum port on the bottom. if i move it to the right bottom port the idle will drop but the one its hooked on now and the top one the idle doesn't change.
where do Chevy's like to pull their vacuum from on these?
Old 03-02-2014, 02:51 PM   #11
geezer#99
geezer#99's Avatar
If you're describing that right and there's no change on idle then it's possible your vac can on the dizzy is blown.
Top one is ported, bottom one is manifold vacuum.
Old 03-02-2014, 03:02 PM   #12
yellow400ex05
so where is better to pull vacuum from a local engine builder told me to pull it from the manifold and other guys tell me to pull it from the top port. and ill check into a new canister.
Old 03-02-2014, 03:08 PM   #13
yellow400ex05
I'll check into a new vacuum canister, but i regardless it shouldn't affect my acceleration at full throttle or under any throttle as an engine doesn't make vacuum when under a load correct?
also since its running really rich, should i try just advancing the timing a good bit more? i just backed it off a little bit ago and its still dumping smoke, the engine seems to like more timing
Old 03-02-2014, 03:40 PM   #14
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
if its that rich...are you sure your choke is working properly?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 03-02-2014, 03:48 PM   #15
yellow400ex05
yes the choke is fully open when the engine is warm
Old 03-02-2014, 03:55 PM   #16
imjeff
imjeff's Avatar
I didn't catch the blowing black at idle. Choke or float. Same with the other symptoms. What rpm are you running when it won't accelerate at WOT!
72 K10 396
75 Cj5 MPI 350 Chev
74 FXE
08 Tahoe
Old 03-02-2014, 03:59 PM   #17
yellow400ex05
im not sure what rpm im at at wot but if i have 3.08's and mash on it at 50mph or 45 i'd say like maybe 2300 these trucks dont come with a factory tach most of the time.
and my choke is fine my floats were adjsuted properly and are below half on both the sight glasses
Old 03-02-2014, 04:01 PM   #18
yellow400ex05
my new plugs are nice and black already with carbon and if i let it idle it'll leave black marks on the pavement.
Old 03-02-2014, 04:04 PM   #19
Gumby
Gumby's Avatar
not PSI but maybe fuel volume problem, its drinking it faster then it gets it whne your on it hard?
Chevy GMC Trucks Find Of The Day
https://www.facebook.com/ChevyGmcTrucksFindOfTheDay or http://ChevyGMCTrucks.com
Gumby is offline   Reply With Quote
Old 03-02-2014, 04:29 PM   #20
geezer#99
geezer#99's Avatar
A motor with your cam likes lots of timing. Both initial and manifold vac for the dizzy.
Usually when you hook to manifold the idle speeds up. If your vac pot is shot then you're likely opening the primary further which uncovers the transition slot and you're idling on the power circuit. That's why it idles rich.
Your secondaries are also adjustable. You can open them a touch and close the primary to get it back on the idle circuit.
You need to check out that vac pot.
Pull the vac hose off the carb and use your lungs. Suck on it real hard and let the suction go and you should hear the pot pop. Or you can reach under the vac pot close to the dizzy and try to feel the rod move. Or pop the dizzy cap off and see if the plate moves with suction on the hose.
Old 03-02-2014, 04:47 PM   #21
INSIDIOUS '86
INSIDIOUS '86's Avatar
With that much cam I'm sure it's idling super rich and your vacuum secondary's are opening. But it's getting over carbed at low rpm like that your losing air speed and signal at the carb. Set your timing without vacuum advance plugged in to 38* at 3000rpm. This is called power timing. It's loud. Kinda scary but it works. Run the rpm up till the mech adv stops adding timing. At that point run timing to *38 you'd initial will be where it's at and there's not much to do to change it without dissecting the distributor. Once you have total timing set plug the vac adv into full manifold vacuum and set your idle and mixture
Now tune the carb. Take your primary jets and run them down two sizes at a time until you get a surge or hesitation at part throttle/light cruise. Once you do go back up two sizes. Once that's done add ten to your primary jet number and that will ball park your rear jet sizes for you. Now tune the secondary spring to your liking. It will prob be either the second heaviest or heaviest spring in a Holley pack but if you can get your kickdown to work you may be able to go lighter on the spring.
If you have issues with setting idle and getting it to run clean let us know
If your distributor is stock then it needs to be recurved. Get a re curve kit but DONT use the **** weights. Change the springs till you get adv all in by 3000 or as good as you can get it but not so week that it adv at idle.
If you need a rpm gauge harbor freight sells some cheap ones $10 that you can quickly wire in under the hood.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 03-03-2014, 02:47 AM   #22
yellow400ex05
well i adjusted and fine tuned the mixture screws and it seems much better, still rich but no leaving black marks on the pavement as of now i and a buddy of mine realized that my harmonic balancer is spun and using a timing light to adjust timing would prove to be entirely inaccurate.
also my plug wires are ancient and only 7mm wires, which may not be enough of spark either to help burn the fuel efficiently. what size wire is good for a BBC? 8mm or 8.5mm? i have HEI ignition as well.
Old 03-03-2014, 05:02 AM   #23
donut
donut's Avatar
HEI, 8mm wires. I believe 7mm were for the older point systems.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 03-04-2014, 10:22 PM   #24
INSIDIOUS '86
The size of the wire is really only based off the insulation thickness. Inside most plug wires are the same. A set of tailors will be fine.
