Suspension clunk - goes away with weight in bed
I have a 1970 C20, trailing arm rear, stock height with front disk conversion and font sway bar.
I have been fighting a clunk for quite some time. If I brake hard I hear the clunk. If I then accelerate, regardless of speed, it clunks. If I accelerate slowly or brake gradually, no clunk. It is more pronounced turning either right or left. I can also feel it through the floorboard when it clunks. Yesterday I hauled a dresser, maybe 150lbs. No clunk! Somehow adding a little bit of weight makes it disappear. Any ideas of what it may be? Thanks! |
Hollister Road Co.
Re: Suspension clunk - goes away with weight in bed
check the trailing arm bushings, also check the center bearing on the drive shaft, lastly check the ubolts on the axle.
Thanks for the suggestions. The trailing arm bushings are about three years old. I have the ECE trailing arms that came with polygraphite bushings. I checked the ubolts on the axle and they are torqued greater than 150 ftlbs.
The carrier bearing is about 5 years old. How is the best way to to check it? The driveshaft seems solid with no play if I grab it and try to move it. |
![]() Join Date: Apr 2005
Check your shock mounting bolts...
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
It'd be alot cooler if you did
x2 on the shock bolts..........
Thanks for the suggestions. Still haven't been able to figure it out. All bushings appear good and shock bolts are tight.
Are you sure its not the rear brakes grabbing sticking and then releasing ? Are the axel seals dry ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Hollister Road Co.
I'd start looking at the front.
Check steering box bolts and frame behind box for cracks? Idler arm? Put jackstands under each front control arm and try to move the wheels up and down left to right while someone looks at suspension with flashlight on bushings etc. Should be no play. Had one mysterious clunk turn out to be the frame though behind the steering box. Also one I had shank style lug nuts on old Crager rims and they would come loose. Acorn from now on.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
Take the shock bolts out and make sure they're not wore out from constant movement. Also check the holes on the mounts. Even if they're tight, they can just appear that way until the weight of the truck moves them.
Daniel 68 C10 Build http://67-72chevytrucks.com/vboard/s...d.php?t=503594 Romans 10:13 Everyone who calls on the name of the Lord will be saved. |
