03-02-2014, 01:33 PM | #1 |
low area on doublewall top.
Hi guys,i been looking at this great site,for about 10 years,a member around 2 years.I bought a 1970 two wheel drive jimmy, off ebay 9 years ago.with a little work from myself and a couple local shops,im starting to see a little light at the end of a 100 mile tunnel,which bring me to the top,a job i might tackle myself, depending on the information i get back,i have a few low area i like to fix,are have fix.I like to know what is the best way and the best material, to use to fix this problem,i have a few small chips and cracks also.
03-02-2014, 02:57 PM | #2 |
Re: low area on doublewall top.
Smc resin is what you want to use.
03-02-2014, 02:59 PM | #3 |
I used Duraglass short strand fiberglass filler, some say to use SMC, I believe thats what they are originally made of. If the low area is on your top you may want to do a search, I haven't came across a good fix for that personally, others may have. Common problem on the double walls.
"85" Monte Carlo SS "71" K5 (SOLD) "64" Chevelle 1930 Chevy two door rat |
03-03-2014, 09:30 PM | #4 |
This isn't a fix technique that many can use. But I had a sag in my otherwise nice double wall top that went away when I mounted my Hickey roof rack. The fiberglass stanchions are contoured to match the top contour, and when I riveted the stanchion to the top it sucked the sag up to meet the stanchion. No more sag!
03-03-2014, 11:37 PM | #5 |
Thanks guys.every little bit helps,i just might, be able to do this myself.
03-05-2014, 01:59 AM | #6 |
SMC is the only way to go from my research. Some guys with knowledge of fiberglass say it will not bond well with SMC and will separate with time. There's a thread on here where a guy repaired his single wall but I can't remember where. Maybe do a search for SMC.
Kirk 72 Blazer CST 4wd highlander |
03-05-2014, 10:54 PM | #7 |
Thanks blazerowner,It looks like thats the direction I'm headed,I just need find out what brand and where to find this stuff.
03-06-2014, 12:48 PM | #8 |
03-06-2014, 10:50 PM | #9 |
Thanks again , blazerowner.
