Old 03-02-2014, 02:10 PM   #1
Eliminator4life
How to disconnect oil pressure gauge
I'm trying to get my bezel out and this cable is holding me up and I got fat hands and advice. Thanks
Eliminator4life is offline   Reply With Quote
Old 03-02-2014, 02:14 PM   #2
imjeff
imjeff's Avatar
Re: How to disconnect oil pressure gauge
Isn't that cable the oil line? They usually unscrew from the back of the gauge.
Jeff
I know a guy who's addicted to brake fluid. He says he can stop any time.
72 K10 396
75 Cj5 MPI 350 Chev
67 Chevelle 396, 4 speed
74 FXE
08 Tahoe
imjeff is offline   Reply With Quote
Old 03-02-2014, 02:41 PM   #3
Eliminator4life
Is oil gonna drip out of it?? How do I get my hand up there to undo it?? You know what size wrench?
Old 03-02-2014, 04:39 PM   #4
earl84
Next to impossible to do that for me, so I disconnected from the engine and just pulled it through the hole in the firewall while it was still attached to the gauge. It will drip a little oil, so just wipe it up after disconnecting from the engine prior to pulling in through the firewall.
earl84 is offline   Reply With Quote
Old 03-02-2014, 04:46 PM   #5
DPowers
DPowers's Avatar
The "easiest" is to crimp it off and then replace when you put it back in. I always have problems with that and the speedo cable.
DPowers is offline   Reply With Quote
Old 03-02-2014, 08:01 PM   #6
1963c-10
1963c-10's Avatar
leave some slack on the line when you reinstall, and you can pull the cluster w/the line attached and unhook it once the clusters got more clearance.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 03-03-2014, 07:21 AM   #7
brokenspoke
brokenspoke's Avatar
On my 65 outside at the firewall was a inline connecter. I unbolted the line at that point and I was able to removed the cluster...I had to gently feed the line thru the hole in the firewall.
brokenspoke is offline   Reply With Quote
