Old 03-02-2014, 05:07 PM   #1
muffintop
how tall is my lift?
so i got a 75 chevy, with a farm raised liftkit im guessing.
i want change the lift in the truck to either a shackle flip or if i got the cash some lift springs.
since i know lifting your truck is not an exact science, but more based on preference. i was wondering how to do i figure the rear lift? and what some of the best options would be for a decent ride quality/price.
thanks again!
muffintop is offline   Reply With Quote
Old 03-02-2014, 05:15 PM   #2
obijuan
Re: how tall is my lift?
remove all of that. all of it. that is a real piece of work.
http://offroaddesign.com/catalog/4inchliftsystem.htm
move your eyeballs over here and take a look at this option. it can be adjusted within reason as well as sourced individually for less.
obijuan is offline   Reply With Quote
Old 03-02-2014, 05:23 PM   #3
vidman
vidman's Avatar
Maybe 6" give or take...If I typed what i was thinking about that picture I would get banned from here
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 03-02-2014, 05:40 PM   #4
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
What's the front look like??
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 03-03-2014, 12:52 AM   #5
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
I would guess 6", based just on the thickness of the second set of springs below the stock springs and 4" block.
I would remove at least the second set of springs (below the clamp) and block, and run a shackle flip. You can see what height lift springs you want from that baseline then.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 03-03-2014, 12:52 AM   #6
muffintop
the crazy thing about the lift though is when i measure from the bottom of the block to the bottom of the factory setup original springs. its about 7.5 inches. so would that be considered a 8inch lift? if so can i get that with shackle flip?
Old 03-03-2014, 01:11 AM   #7
dieseldawg142
dieseldawg142's Avatar
no, shackle flips come in 2 & 4 inch lift. if you want cheap, put 4" flips in & a 2 or 3" block
dieseldawg142 is offline   Reply With Quote
Old 03-03-2014, 10:52 AM   #8
1tuff71
1tuff71's Avatar
WOW that's a real mess there. Yea go with diesel's suggestion and get a 4" shackle flip and the blocks or get a good set of 8" springs from Alcan or ORD and get that "FUBAR" out from your truck.
1tuff71 is offline   Reply With Quote
Old 03-03-2014, 02:11 PM   #9
muffintop
thanks guys. the front in my honest opinion was done properly with new leaf springs.
im pushing more toward buying two new 8inch leafs now that i know id have to still block the shackle kit. trying to make her into a trailer park queen.
like they say, you can take a truck out of the trailer park, but you'll never pull a trailer park with a trailer park truck.
you guys got any ideas on which company to go with for the leafs? i looked at alcan and ord last night for an hour or two. thanks 1tuff71 for the advice. but is it not worth looking at like tuff country, or maybe super lift something? with ez ride?
all the shocks on the poor girl where rusted through. they would make better modern art than compression. got any ideas on shocks as well? is it worth the money to buy good shocks? or is there no difference after $100+
Old 03-03-2014, 04:29 PM   #10
dieseldawg142
i have skyjacker 8" springs on my crew for almost 10yrs. they have 8" rear springs, but there not cheap.
http://www.stylintrucks.com/parts/le...7cr18rear.aspx
i used flips & blocks in the rear of my crew, under $200
a 4" spring & flip or block would give a better ride than them 8's. although with what you got your prob used to it!
a good nitrogen shock works well with big tires
Old 03-03-2014, 06:47 PM   #11
TheBlueBomber
TheBlueBomber's Avatar
That must be that 1.5 ton suspension I keep hearing about.
Austin
1996 Chevrolet K1500 Silverado
1979 Chevrolet K10 Scottsdale - Carolina K10 -
My 4.8L Twin turbo build - Project Short Stroke -
Instagram - TheBlueBomber1996
TheBlueBomber is offline   Reply With Quote
Old 03-03-2014, 08:27 PM   #12
1tuff71
1tuff71's Avatar
yea I have Superlift on mine and their a bit stiff but it's a trailer queen and never even see's rain so I don't mind the ride and yes Alcan's are $$$$$ but you get what you pay for.
Old 03-03-2014, 08:54 PM   #13
obijuan
flip a stock spring with that block you have now. all the white body shocks are made in the same factory with a different sticker.
on a mercedes benz, yes bilstein all the way. these trucks ride the way they ride. shocks just manage the bounce. a good procomp 9000 will do well.
Old 03-04-2014, 09:41 PM   #14
swamp rat
swamp rat's Avatar
I'm sold on full arch springs and ORD's replacement shackle for the rear, i have a 4" lift.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-06-2014, 12:34 PM   #15
1tuff71
1tuff71's Avatar
Find some "softride" 4" rears from Tuff Country or Superlift and go with the 4" shackle flip or just go for the 8" springs and your back will thank you for it. Don't use any blocks they just promote axle wrap.
