Keyless Entry
Hi guys, I recently picked up a '95 K2500. This truck was not factory equipped with the keyless entry, I know this from checking the SPI sticker in the glove box.
My question is...Has anyone ever added an OEM keyless entry system? As far as I can tell the system pretty much just consists of the keyless entry module (receiver), the harness for it, and the remote. I know where the keyless entry module would normally mount under the dash, since I've replaced them before, so I looked around that area and didn't see any loose connectors that would go to a keyless entry module, but maybe its taped up somewhere that I can't see. I'm really only interested in adding an OEM keyless entry system, not any aftermarket options that require a lot of wire splicing and quit working after a few years anyways. If anyone has any info about this it would be much appreciated
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB Last edited by BigRed76; 03-02-2014 at 05:22 PM. Reason: spelling |
Re: Keyless Entry
Anybody?
Anyone have opinions on the best aftermarket keyless entry system?
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
Re: Keyless Entry
Here is a start http://www.commandocaralarms.com/keyless-entry.asp
cheaper if you have power door locks in the truck. |
#4 | ||
Re: Keyless Entry
You can access the schematics for your truck either in a library, or dealers like ours here let you copy the shop manuals. If you don't want to actually purchase your own copy. You could also search vehicles in junk yards for components needed. |
Re: Keyless Entry
OEM keyless entry was not a option in 1979.
Using a later OME and trying to mate could work but will require the use of a BCM and a matched receiver and key fobs and a fair amount of time. That's why I posted the link for an idea to use aftermarket keyless system as its straight forward to use. |
#6 | |
Re: Keyless Entry
But I don't have access to a truck with OEM keyless entry to see if the keyless entry wiring is a separate harness or not.
Re: Keyless Entry
They aren't going to make a different harness for trucks with and without power door locks. The harness will have the connectors on it but won't be used. Look at a vehicle with components in place and then verify it on your vehicle. Then go back and buy the components.
#8 | |
Re: Keyless Entry
Re: Keyless Entry
It is a separate harness but it is also part of the PW harness, but I doubt that you have the connectors for the keyless. The RKE added a relay that regular 2 door pickups did not have.
I am working on installing factory RKE in my 1989 Sierra. Because i do not do aftermarket parts and the only mods that are not GM are the rear view mirror and the Jeep steering shaft.
Jay 2001 Pontiac Aztek GT |
#10 | |
Re: Keyless Entry
My truck does not have the connectors for the RKE module, I've looked multiple times. What route are you taking for installed RKE in your Sierra? Getting a used power window harness and installing it in your truck? I have no problem with aftermarket parts, just with aftermarket keyless entry systems
Re: Keyless Entry
You won't need to wire the power window part of the harness in, just the locks, so you can leave that part alone.
Here's the RKE wiring diagram so this will help tremendously. I got the relay from an S10 Blazer and using the RKE module from a 1995 Pontiac Grand Prix and tying in to the factory harness. I've almost got it done, just a few bugs to work out.
Re: Keyless Entry
Ok. So you went ahead and made your own harness to add on rather than trying to swap out your existing harness.
#13 |
Re: Keyless Entry
Correct.
| Bookmarks |
