Old 03-02-2014, 06:31 PM   #1
kjc292
kjc292's Avatar
inline 292 2 barrel questions
Hey guys, first post in the 67-72 years. I have a 78 c20 with a 292. I have a few questions about carbs and figure I'd have better luck here than where I usually post/look. Currently the motor has a stock intake/exhaust and the monojet carb electric choke. So my question is what two barrels work? I really dont mind fabricating a plate to fit the 2 barrel to the stock intake. Im not looking at buying the 600 clifford intake/exhaust setup. just dont have the cash right now, will purchase all the good stuff once Im able to pull the engine out. I saw the 32/36 webber on steve langdons. If i could find a original carb and buy a rebuild kit i dont mind that either. Thanks for any help.
79' c20 std cab 292 3speed granny - daily driver.
77' c30 std cab 454 th400 4.10 - fathers truck then mine.
95' ford bronco 302 4speed overdrive.
2002 mustang auto v6 - girlfriends daily driver.
Debt just means that you had more fun than you're suppose to have
kjc292 is offline   Reply With Quote
Old 03-02-2014, 08:21 PM   #2
trac209
Re: inline 292 2 barrel questions
You can buy an adapter that will fit a Rochester 2 bbl onto the mono intake. Summit racing sells them.
trac209 is offline   Reply With Quote
