Wheel help needed
Hello all, I picked up a 68 GMC Stepside. As you know I have drums all the way around and just want to bolt on some wheels/tires for now.
I am looking for something like 20's on the front and 22"s on the rear. I don't have the funds to do an Air-ride yet so I will just do a drop kit front and rear. The drop I am sure depends on the wheels. I would like to bolt on wheels without spacers as I like the deep dish look. I like the 5 spoke look also. Anyone do this to their truck? I would love to see a picture if you have. My truck is black and I was thinking about black or Gunmetal wheels with a chrome lip or something like that. Thanks for your advice. I read thought this forum each night till my eyes dry out and then head to bed ![]() Thanks Will |
Re: Wheel help needed
Here's a pic of the truck I just picked up. Its a completely rust free truck. I got real lucky.
![]() Join Date: Dec 2013
that's a nice truck , sweet
I will do a ECE 4/6 drop and go to discs in the front and run spacers if that helps out with my question.
nice truck any plans to swap the rear fenders?
70 SWB STEPSIDE 70 BLAZER 09 challenger |
I had no plans on swapping fenders but I will look into it. I never even though of that one.
I have a mildly built LS 5.3 and 4l60e I am swapping in. I build my own harnesses and reprogram my own computer to match. Here's a pic of the motor/trans combo going in. |
Good looking truck.
Something to consider on suspension is installing air bags and using schrader valves instead of an air management system. This will allow you to not have to swap out suspension whenever you do decide for air ride. Then when funds allow for the air management you simply add it to your suspension. Being you are in Louisville, there should be some good deals on wheels at the swap meet this weekend.
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
Just talked with ELE about a 4/6 drop kit with disc brake conversion on front. They ask me about 5 lug or 6 lug. I like the BOSS 338's but don't see them in a 6 lug.
I would like to run 20x8.5's and 20x10's Should I go with a 5 lug conversion and convert the rear to 5 lug so I can run these wheels or can I just do the 6 lug. I just don't see the wheels in a stock 6 lug 5.5. |
![]() Join Date: Jan 2014
Picked up some 22's off CL here in Phoenix for my '69 long bed to shortbed project. Seems most 22s meant for new Silverado's have a 6" back spacing and are 10"s wide. Mine have 305-40-22 tires. Tight fit. Front is still stock height. Will be dropping it around 3-4's. should still clear. Barely rub the shock at full lock.
For the rear i scored a pair of 2" spacers. I think 1.5" would be better. FWIW, my truck has leaf springs. Currently only running the 2 main with the overload. Also lengthened the shackle 2"s. Once the tailgate is mounted and the 25 gallon blazer tank is hung under the back the rear will sit where I want. the 305's are a full 32"s tall. |
Appreciate the help, I will check around here locally.
![]() Join Date: Oct 2013
when you switch to disc brakes go for a larger than stock upgrade - will make wheels look better and stop better.
![]() Join Date: Nov 2001
5 lug
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
#13 |
![]() Join Date: Jan 2011
Just a thought ..
IF you're interested in Boss 338 and you do go with the 5 lug conversion, my Dad has a set of chrome 20x8.5 with brand new tires on them. I know they were $1,600 new, you might PM him to see if he'd want to sell them. He has talked about it. His forum 'handle' is NoNeck. Im sure you could get a deal on them and pick them up, no shipping, etc. We're not too far away from you. 10" wheels will be tight on your stepside. Most guys will run a 8.5 all the way around on the steppers. .. it depends on which rear end housing is in your truck. The earlier years were .75" more narrow on either side. I can ask him about the 338's if you're interested. all 4 are 8.5" wide. 275/45/20 tires. They'd look good on your truck with a 4/6 drop. On the bed fenders, your truck has a 1973+ year model bed on it. The 67-72 model years had a rounded wheel arch (like the front) It's not the end of the world but that's why the change was suggested .. I think you can swap 67-72 fenders on it I'm not sure.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
