03-02-2014, 10:18 PM | #1 |
brake system help!
hello Im getting ready to plumb my brake system on my 57 3100. its has a 74 camaro clip and a 79 Trans Am disc brake rear. Im keeping the the MC under the floor without a booster. its the TA master cyl. i have the disc brake rear prop valve also. im not sure if I should run the stock prop valve or run an adjustable? or both? Are there residual valves built into the TA prop valve or do i need to add them? diagrams ive seen dont show both residual valves and prop valves. I know this has been discussed but i couldnt find it. thank you in advance
03-08-2014, 09:00 AM | #2 |
Java Mechanic
Re: brake system help!
This thread slipped below the fold. Can anyone help here?
Keith 11 Lincoln MKT -- Momma's wagon 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
03-10-2014, 08:19 AM | #3 |
Java Mechanic
Can someone help with this question?
03-10-2014, 10:43 AM | #4 |
Can't tell you anything about the MC, but with the MC below the cab I would install the residual valves, just to play it safe, because the MC is lower that the disc brake puck and rear wheel cylinders...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
03-10-2014, 12:06 PM | #5 |
Agree.
Additionally, since you are now disc/disc you shouldn't need the hold off portion (delays actuation of a disc brake until the rear drums can be applied) in the production combo valve. So - my recommendation would be to eliminate the factory combo valve and use an adjustable valve on the rear, and then dial it in where you want it via experimentation. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
03-11-2014, 10:14 AM | #6 |
thank you! I found an adjustable rear bias prop valve to replace the TA valve. definately going to use residual valves. thanks again!
