![]() Join Date: Dec 2013
couple Qs puttin this 69 c10 back together
So i put a 86+ 350 in the truck and my first question is about the coolant temp sensor. The 69 is a 1/2" thread and the 86 is a 3/8" but a little diff single terminal hookup. Does anyone know if the diff year sensors will read accurate or not with the 69?
Also the ps pump where it mounts to the wp has a gap in the back side and is threaded in the beginning. Previous owner just had a 1.25" long bolt holding it on but im sure the bolt needs to go all the way thru and thread into the bracket. Is there a special bolt for that? And can anyone provide a pic for the mounting bracket where it attaches to the factory exhaust manifold? Btw im still low on thread posts so i cant post in the classifieds. Thanks gents....hopefully i can get this thing up n runnin sometime next week. ![]() Last edited by leddzepp; 03-03-2014 at 01:07 AM. |
Moderator
![]() Join Date: Jun 2008
Re: couple Qs puttin this 69 c10 back together
The sensor that is correct for the newer block won't read correctly. The ohms are different. I had member brian mac on the board re-thread a 67-72 sensor from 1/2" to 3/8" for me.
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
Moderator
![]() Join Date: May 2007
Welcome to the board. You cannot post in the classified section because you are not a subscribing member. It is $15 for 6 months or $25 a year and you can post a wtb ad. You can also cruise the parts board and see what other members have for sale in the meantime.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
well....thats disheartening. but i pm'd the guy for one. thanks.
ahh ok. that makes sense then lol. im just used to having a certain post total before certain privileges but ok. |
Yeah not sure if that guy is active still cuz no response yet. Maybe ill look into an adapter.
![]() Join Date: Jan 2013
Out of curiosity, what are the ohms supposed to be?
check summit racing they usually tell the ohms and might can the right size with right ohms there,
