Old 03-02-2014, 11:50 PM   #1
tjsblazer
tjsblazer's Avatar
water pump application
I have a 72 Blazer K5 with a 350 small block. What would the factory water pump be the short or long version?
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 03-03-2014, 12:00 PM   #2
turp mcspray
turp mcspray's Avatar
Re: water pump application
Factory used a short pump.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 03-04-2014, 09:37 AM   #3
Chulisohombre
Chulisohombre's Avatar
Most trucks I've seen had short pump. Not sure if ac trucks had long pump.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
Old 03-04-2014, 12:51 PM   #4
tjsblazer
tjsblazer's Avatar
Thanks guys. Most of my reading is saying up to '72 used short then switch to long in '73. I wanted confirmation from the board. It is generally the best source of info.
Cheers.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
