WTB: BBC triple groove crank pulley for SWP
Looking for a steel triple groove pulley... or a double with a add-on single for a power steering pump. All three pulleys should measure 6 3/4" in diameter.
Anyone? Again, this is for a Big Block Chevy with a short water pump. |
Re: WTB: BBC triple groove crank pulley for SWP
Might have what you need, I will check for you tomorrow.
Adam |
Sounds good. Please check and see!
I'll keep the set in mind but really only need the triple pulley for the crank. Unless you mean by a set is the double and single for the crank as an assembly.
[ATTACH]1222529[/ATTACH]
Is this what you're looking for? I could do $50 shipped to your door. |
"Trucks with Class"
![]() Join Date: Jul 2000
This is the correct set...
Moderator
![]() Join Date: May 2007
The set that Frank has pictured is the correct set up for a big block with a short water pump.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#8 | |
Always on the hunt...
![]() Join Date: Sep 2006
I'm running aftermarket Alan Grove brackets. Short water pump.
My water pump pulley is 6 1/4". Don't have it in my hand to check the number. I was just going to buy the two I need from Alan Grove but it's a pretty pricey pair new so I was hoping to find an OEM combo on here cheaper. According to Alan Grove, all three pulleys need to measure 6 3/4 for me with their brackets and a 6 1/4" water pump pulley. http://www.alangrovecomponents.com/Pulleys_2011.htm |
Still looking for the right combo with a 3 groove pulley where all 3 are 6 3/4.
#12 | |
#13 |
"Trucks with Class"
Those are now SOLD locally, but here is a three groove set (6.75"), exactly as you asked for...
#14 |
#15 |
