Quit if it's not FUN!!!
Driveshaft confusion
Is the length of a driveshaft different between a long bed and a short bed? 350 vs. 400 turbo? I need some clarification quick ! !
MY MOTTO: Eat it all up, Wear it out, Use the last few drops, Spend all you've got, Late in life, you'll think of the things you didn't do, not the things you did. - Get out and experience life ! . Robbie Robinson a.k.a. TobyArnot (Toe Bee or not toe bee) ![]() |
Re: Driveshaft confusion
Yes, and yes.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
O.K. - What is the length of a short-bed d/shaft for a 350 vs. a 400 turbo trans???
![]() Join Date: Oct 2010
The main housing dimensions without tail shafts are:
TH350 21.75" TH400 24.37" So driveshaft should be about 2.6 inches different. Hope this helps.
1972 Chevy LWB Roadster 1999 Chevy Silverado 2wd 2015 Chevy High Country 4x4 Crew Cab |
No one is going to know exactly other than yourself after you measure.
![]() Join Date: Oct 2013
I'm currently trying to replace my shaft on a longbed 350. what's the typical length for a 70 c10 350 tranny longbed front shaft coming off the tranny?
the boat guy
There's about a dozen places the engine and transmission can be mounted using factory parts. Unless you and another person have the same engine stands, in the same mount holes that have or have not been swapped side to side to ask.
Its best to just measure your truck. A driveline shop can modify your shaft or build you a new one for a lot less time and money that trying to make a junkyard shaft work.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
#9 | |
Those are some points I had not considered! Thanks for the response, it was helpful! Danny |
