03-03-2014, 12:52 PM | #1 |
How to fix this Rust on the Firewall?
03-03-2014, 12:58 PM | #2 |
Re: How to fix this Rust on the Firewall?
Id look for a donar firewall that you can cut up and use.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
03-03-2014, 01:01 PM | #3 |
I would say for that you will need another cab for a donor. There are some doublers behind that area for the bolt plates and the spotwelds will have to be cut out. Cut splice and weld in the new sections. Gonna be a big job.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
03-03-2014, 01:03 PM | #4 |
Thank you. I thought it was going to end up being a bigger job than I wanted.
I will keep my eyes open for a doner that I can pick up at an affordable price. |
03-03-2014, 01:40 PM | #5 |
you could just use some sheet metal a fab that. it wont be stock. but it will be fixed.
03-03-2014, 01:42 PM | #6 |
No need for a donor cab, just cut out each layer and make patches for each layer. I did it on a '65. It's not an easy fix since there's 2-3 layers in places. If your firewall is that bad then you also need to check the seams on the bottom of your cowl, inside the cab. You'll probably have to pull the inner fender mounts as well to get it all out.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
03-03-2014, 01:46 PM | #7 |
Too bad your so far away. I have an extra cab..
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
03-03-2014, 01:55 PM | #8 |
Might be worth the drive for a CA cab.
03-03-2014, 01:55 PM | #9 | |
Just about my luck. Thanks though. |
05-28-2017, 01:35 PM | #10 |
This is what I am doing to a 1969 GMC that has the firewall rusted out along with the ducting inside. This is a necessary issue to be corrected because the heater box begins to separate from the firewall and you will have wet floor and firewall inside the cab anytime you wash your pickup or when it rains.
Also it can let fumes in the cab. This is a simple yet effective repair that will hold the firewall together. When this area is rusted out there is nothing to support the heater and brake pedal mounting. The 1" square tubing works very well. The windshield wiper motor mount will need repaired also. Youtube videos here: Part 1: https://youtu.be/nBBQPQAUfX8 |
05-28-2017, 08:47 PM | #11 |
IMHO it depends what you are shooting for, I see it as fixable but I am by no means trying to get a show truck, my truck is worse than yours by far and still not going the Cab swap route. As you can see from other posts its completely doable keep us posted as it will help other like me
1966 Chevy C10 Not named yet, help! 1984 GMC 4x4 SB "The Hunter" My 66 C10 fun build: http://67-72chevytrucks.com/vboard/s...d.php?t=738705 |
05-28-2017, 08:50 PM | #12 | |
Great pics! thanks it helps me too as mine is farther gone
05-29-2017, 01:26 PM | #13 |
It is going well so far, I have moved to the center section where it is the worst, every thing has separated or disappeared. I have come up with a solution using the part of the square tubing I had cut out.
Once it is complete with the welds smoothed off, sealant applied, and a coat of rattle can paint it will be a clean repair. Won't look original but this isn't a show or concourse pickup. Video of Center Repair: https://youtu.be/OEJtv1E3X7k Play List of Entire Repair to date: https://www.youtube.com/playlist?lis...JX3IJCPpHJcaTp |
05-29-2017, 03:21 PM | #14 |
Nice. I'll have to remember that idea. I always have some C-channel and square tubing around.
05-29-2017, 03:37 PM | #15 |
I used only square tubing, the pic is of the first piece I cut and the cuts were made on the same side. Later I cut the piece out on 2 sides because I didn't want lip on firewall side but I like the straight bent edge left on the engine side.
The square tubing is nice because the corners aren't heavy like most angle iron and some channel. You can make a cut off wheel go a long ways if you go back and forth over the cut line until it goes through, if you make the whole cut cutting on the edge of the steel the cut off wheel disappears before your eyes. You can see the groove made in the pic where it hadn't gone through yet. |
05-30-2017, 04:14 PM | #16 |
Nearly Finished, got the center portion looking so-so.
A little paint and it won't look to bad. Part 4 Video: https://youtu.be/zZCpe9iEEEw Playlist of repair: https://www.youtube.com/playlist?lis...JX3IJCPpHJcaTp |
