Old 03-03-2014, 05:24 PM   #1
Bigru
Bigru's Avatar
Shortening Steering Column #2
Hey guys i would like to collect 2" of room for my midsection lol.
First of all i saw this link http://67-72chevytrucks.com/vboard/s...light=steering and went over it several times.
This is done on a 71, has anyone done this on a 64-66? Can you please chime in on what would be different. Any pics, do's and don't, what size knuckler is needed and where to buy? Thanks for you help. Rudy
1965 Short Fleet
http://67-72chevytrucks.com/vboard/s...d.php?t=637478
1983 Short Fleet (Under construction for my 13 year old son)
2008 GMC Denali
2012 Harley Roadglide
Follow me on Instagram: Ru_django
Bigru is offline   Reply With Quote
Old 03-03-2014, 05:40 PM   #2
NEWFISHER
NEWFISHER's Avatar
Re: Shortening Steering Column #2
Scroll all they way down here:http://www.67-72chevytrucks.com/vboa...d.php?t=559678
that is the FAQ section at the top of the 60-66 forum
I used a 74ish van column and shoved it all the way into the dash ( 6'4" 250 lbs), used the 65 column mount and the cut the shaft to fit the rag joint, bolted it together and wired it using the same colors
http://67-72chevytrucks.com/vboard/s...d.php?t=133937
http://67-72chevytrucks.com/vboard/s...ad.php?t=63328
http://67-72chevytrucks.com/vboard/s...ad.php?t=33591
http://67-72chevytrucks.com/vboard/s...d.php?t=147927
http://67-72chevytrucks.com/vboard/s...d.php?t=226398
http://67-72chevytrucks.com/vboard/s...d.php?t=147355
http://67-72chevytrucks.com/vboard/s...d.php?t=277856
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 03-03-2014, 07:02 PM   #3
Bigru
Bigru's Avatar
none of these links work.
1965 Short Fleet
2008 GMC Denali
Old 03-03-2014, 07:40 PM   #4
NEWFISHER
NEWFISHER's Avatar
You will find them within the first one I posted to the FAQ section, scroll down to Steering and they work from there
GOD BLESS AMERICA!
Old 03-04-2014, 03:58 AM   #5
j_persinger66c10
On a 64-66 chevy steering column they are a 1 piece (Chest Crusher) shaft and the only way to shorten them is to either remove the column and cut it down the weld it back together with a 3/4" x 3/4" round coupler.
The other route is to put a different column altogether in and this will give you tilt steering and the option to shorten the steering. I put a 79 chevy van tilt steering automatic column into my 66' and used an intermediate shaft from a 67-72 chevy I was able to get everything at a local salvage yard for $100. I had to drill out the nylon stops for the intermediate shaft and then soak it in some transmission fluid to let the rust break up. Then I took the knuckler apart and used a 2x4 and hammer to move the shaft down about 4" or so. I also used the bottom half of my old rag joint and mated it to the top half of the rag joint on the intermediate shaft. I also had to notch out my brake pedal housing to allow clearance for the Neutral safety switch and notch my inner fender well to allow clearance for the knuckler on the intermediate shaft.
After all of this and removing my gas tank from behind the seat I gained a total of about 6 to 8" of belly room. So I am able to comfortably fit great and I am a big man at 6'1" 374lbs.
j_persinger66c10 is offline   Reply With Quote
Old 03-04-2014, 05:53 AM   #6
AUS64c10
Another option if you have the funds is to get an aftermarket Ididit column. I just put one in my 64 and was able to set it up really close to the dash. Having the tilt does add a bit of extra length to the column inside the cab.
http://67-72chevytrucks.com/vboard/s...0&postcount=27
i did have to fit new intermediate shaft using Borgeson products that added a couple of hundred extra to the conversion as well.
Another option is to look at the Goldilocks thread as the astronaut did a really nice job shortening the original column in his '65
http://67-72chevytrucks.com/vboard/s...=474456&page=8
AUS64c10 is offline   Reply With Quote
Old 03-04-2014, 08:39 PM   #7
number10
New guy here and do not have pics yet but I took the shaft out of my 66 column and after cutting to lenth milled flats on 2 side so a DD shaft from factory round. This allowed me to use the extention that came with a power steering convertion kit. The bearings on the lower end of the column tube were missing so I machined an aluminum sleeve to accepted a harley cam bearing. Now if I only had floors.
number10 is offline   Reply With Quote
