Old 03-03-2014, 08:21 PM   #1
djl95
djl95's Avatar
Are the frames the same?
Hey y'all. We have a 77 three quarter ton chevy donor. We are wanting to build a 80 crew cab chevy. All of them for sale around here are 2wd. But we have been told that's the frames are all the same and drilled for 2wd and 4wd. Can anybody confirm this? Thanks
72 Chevy lwb, ps, pb, 355, big cam, th350, tach, posi, leaf rear
04 Ford F-250 6.0 powerstroke crew cab long bed, MBRP 4 in. Straight pipe, ARP headstuds, sinister diesel coolant filter
97 Ford F-350 7.3 powerstroke 4x4 crew cab long bed 5 speed, stage 1 injectors, straight pipe, 250,xxx miles and running strong
djl95 is offline   Reply With Quote
Old 03-03-2014, 08:47 PM   #2
LONGHAIR
Re: Are the frames the same?
No, they are not the same. The front crossmembers are very different and the framerails themselves are shaped differently from the cab back.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 03-03-2014, 09:43 PM   #3
burban nate
I am in the process of converting an '85 crew cab dually 2wd frame into 4wd, for my '90 V3500. The 4wd frame is to hacked on, bent, and rusty to use. I'm using all the 4wd specific parts on the 2wd chassis. I can tell you while it is possible I do not recommend doing this. I'm already dedicated but had I known how much screwing around this would be I would have done it different.
The rails are shaped different in front of the front cab mount and my not provide enough clearance for the front leaf spring. The steering box mount is different between the two. The rear spring hangers are longer on a 4wd and the 4wd specific holes do not line up with the 2wd frame. The 4wd core support mounts are different and the holes don't line up with the 2wd frame either. Although, I believe the 2wd is a stronger frame because it doesn't neck down from 8" to 6" in front of the front cab mount.
Nate
burban nate is offline   Reply With Quote
Old 03-04-2014, 12:37 AM   #4
burban nate
After working on my frame I've decided to splice the two together at the front cab mount. The frames are to different in the front clip that it's the only way I see getting a usable frame from the two.
My front frame horns need a little tlc but the real reason for using the 2wd frame was because it has rust free straight not welded on rails. The front clip from the 4wd frame is still good.
Nate
Old 03-04-2014, 05:31 PM   #5
1968vetL-71
Junior Member
1968vetL-71's Avatar
I'll post some pics of my conversion in a day or so. Not bad, I robbed my stuff from a cucv. I built a engine crossmember from a tcase crossmember. Turned out great till it gets a Cummins conversion.
1969 impala conv 427 #s loaded. dad bought new
1969 "Judge" RA-3, rare warwick blue/white, #'s
1968 vet convertible #s 427/435 tripower (sold)
1968 belair 2door post #s 427/385
1936 ford 5w coupe dads 1st car
1969 camaro ss (17,xxx) miles
Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project.
1968vetL-71 is offline   Reply With Quote
Old 03-04-2014, 08:26 PM   #6
nekkidhillbilly
http://www.gm***************/forum/s...ead.php?t=2843
http://coloradok5.com/forums/showthread.php?t=82107
basically if you can use a drill and find a junk 4wd it will work
nekkidhillbilly is offline   Reply With Quote
