Old 03-03-2014, 08:49 PM   #1
69Beauty
69Beauty's Avatar
What goes in this hole? Cab corner...
I am replacing the floor in places along with rockers and floor extensions and the cab supports. The PO filled this area with foam when he replaced cab corners... I know that the floor extension meets the rear support hear but does anything touch the cab corner to seal off the cab? I am stumped... Maybe I just can't see something. Image is flipped 90 degrees for some reason. Sorry
1969 C-10 LWB 388 SBC Vortec Heads 10:1 Lunati 60103 cam Weiand intake Quadrajet Carb 12 Bolt 3:73 posi 700r4 Hedman Headers
1998 Dodge Ram 1500 Reg. Cab Long Box 4X4 5.9L 183k miles
1956 Ford F-100 Longbed with Original 272 and 3OTT
1995 C1500 ECSB 6.5 Diesel 4l80e (Camper puller)
1997 Dodge 3/4 ECLB V10 (MPG machine)
69Beauty is offline   Reply With Quote
Old 03-03-2014, 09:04 PM   #2
Kennuck
Kennuck's Avatar
Re: What goes in this hole? Cab corner...
Thats the way they are made. Keep the dirt from accumulating in there and it won't rust out so easily.
1970 Short Wide
5.3 4L60E BlackBear tune
3:73 gears, Boyd's Tank
2.5 / 4 drop 5 lug disc brakes
Vintage Air
18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear
Kennuck is offline   Reply With Quote
Old 03-03-2014, 10:23 PM   #3
turp mcspray
turp mcspray's Avatar
I always thought they were there as a place to store dirt!
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 03-03-2014, 10:53 PM   #4
Lou Boffa
Lou Boffa's Avatar
and on the passenger side, the tire tool and jack handle bag (along with the dirt etc)
Figure out what you want--then figure out what you are willing to give up to get it.
Lou Boffa is offline   Reply With Quote
