Lower Rear Short Bed Patch Panels Help!!?
So I ordered these Lower Rear Panels from LMC, driver and passenger side (Part #'s 38-7274 / 38-7275) and they're not even close to a match.
First off you can only buy them in Longbed and have to be cut down (I anticipated this) So I get them in and the body lines don't match up, it doesn't have the bevel line down like the factory edge of the bed does. The panel goes well above the taillight location and also doesn't have the mount for the support brace under the bed. So my question/hopes is someone could point me in the direction of an ACTUAL replacement that will work. I see Brother's makes a nice one but was hoping for advice before I throw away more $ on a part that won't work. To make things worse, after I pay shipping, + restocking fee I would get back $10 if I was lucky, so I'm stuck with junk panels. On a positive note, so this isn't a Rant! I replaced the passenger rocker from LMC as well, and it fit great ![]() Link to LMC diagram, #5 on the list: http://www.lmctruck.com/icatalog/cb/full.aspx?Page=27 Panel on actual bed, as you can see lots of bondo here: |
Re: Lower Rear Short Bed Patch Panels Help!!?
Bump!
Someone has had to replaced this before. Anyone!?? |
i went to the junkyard and cut one from a bed there.
CAN'T FIX NOTHIN
I'm just guessing but it sounds to me like the one you have will work just fine you just need to trim it down aftermarket body panels are not direct fit they never were and never will be , for example the right front fender patch they make is to short about 1" or so to short I put mine on and had to cut it in half and add metal to lengthen it , if I patch another front fender I'm gonna order two of the patch panels and cut them in half to make one , long story short patch panels are something to work with post some pics of that patch held up against your bed and I can assist a little better ,
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
![]() Join Date: Jan 2011
Hey -- I may have a patch panel that would be perfect for this. I bought a long bed (As you mentioned) patch panel from American Metal Direct so I could get the front lower corner (right behind the tire) So I cut out what I needed, and I still have the back side of the panel. I am 99% sure it wraps around the back edge too..
The only problem is I cant remember if it's Driver or Pass side. IF you're not in a big hurry I can check on it for you. Just pay shipping and it's yours. It's at my Pop's house.. I'll check on it for you if you want.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
#6 | |
I kept the old piece just incase I have to piece it together, There's not a rush but it's irritating ya know (haha) If it turns out to be the passenger side and you're not using I'd love to have it. I actually have to do this on the driver's side too but it's no where near as bad with bondo so unless I find the correct parts I probably won't mess with it. Just let me know whenever you get around to looking at it. Thanks CC69Rat ![]() |
Here's a picture of it. It is the pass side. I could just cut it off so it's not as long and it may fit in a flat rate box. I just needed the area right behind the tire (what part you see cut out of course)
let me know if you want it.
It looks pretty similiar to the LMC one but it's worth a shot, if you're sure you don't need it I'll take it. I won't need the whole thing if you would cut of the excess piece i'd appreciate it.
I'm assuming you have a Paypal account? If not just PM me where you would like me to send the money to and how much $ Thank You again |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
Nobody has a rear lower section that matches the truck. All that are out there are what are referred as crash parts. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
![]() If it's the same as what you have now and not what you need, no sense sending it (?) I just saw a need for something I had laying around.
CAN'T FIX NOTHIN
You can ,, that piece can be made to work ,,,
