3.07 posi rear end with:
How would this rear end match up with a th350 and 350 motor in a 72 4x4 blazer?
Other option is with a 69 292 power glide set up? It would be nice to have that extra tire spinning on some of the hunting trips I go on. Thanks. |
Re: 3.07 posi rear end with:
What gear do you have in the front axle? And what diameter tires?
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
Wide n'Low
![]() Join Date: Jan 2007
It's my experience, many of the 350/350 setups I have come across in Blazers had 3.07/3.08 standard.
I have seen a few 3.73 combo's too, but as mentioned you need to match the front & rear.
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
Base model diff ratio in a 350 powered 4x4 '71-'72 would have been 3.07 gears while the optional gear was 3.73. I own (2) '72 Jimmys about 1200 serial #'s apart. Mine I learned to drive in is a 4 speed and came with 3.07. The other one that will eventually be my 10 year olds "project" is 3.73 and an auto.
What size tire do you have is a great question. IMO, 3.07 just isn't enough gear for 33" tires. 3.73 is ideal for that and 4.10 for 35's.
Wide n'Low
Agree on the size of the tires,
I have a 75 Blazer with a 4 spd/205 so, (same 1:1 final ratio) and 3.07 gears, running 33's. Sucks around town and on even seemingly minor hills, but great running down the freeway..
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired Last edited by Twisted78SS; 03-04-2014 at 02:49 PM. |
3.07 is not too bad as long as your tires are no bigger than 31" with stock trans
just put the t/c in low range when you have to get with it
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
