Brake Hose Question
I'm working on my son's truck, and the front brake hoses furnished with the McGaughys "Big Brake" Kit seem too be about an inch short to reach the caliper. Dumb question, but does the hose run on top of the upper control arm or underneath? Here is a photo for reference.
Thanks, POP
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
Re: Brake Hose Question
ECE setup is under.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
Yes, under, and there is a right and left.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
71-72 trucks (with discs) ran the brake lines on the front of the cross member and the crossmember had a support bracket for the hoses where they connected with the lines. Attached is a picture of the 71-72 crossmember showing one of the brackets where the hose was supported as it was to be connected to the line.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC Last edited by JimKshortstep4x4; 03-04-2014 at 11:40 AM. Reason: Added wording |
