Old 03-04-2014, 09:44 AM   #1
marina blue bob
marina blue bob's Avatar
Troubleshooting 350 flatspot- need forum help
Need your help ---
1. I've got a flat spot where the engine just dies (like you shut off the key) when trying to accelerate above 2000 rpm under load.
2. It starts fine, revs fine just sitting still with no load. Do you think
it's carb or distributor related ?
3. Been thinking it may be stuck mech advance. Trying to decide where to start diagnosing first.
Appreciate anyone's help.
Details:
67 K20
rebuilt Chevy 350
Holley Truck Avenger 4bbl - 670cfm
Mallory HEI distr
marina blue bob is offline   Reply With Quote
Old 03-04-2014, 10:38 AM   #2
geezer#99
geezer#99's Avatar
Re: Troubleshooting 350 flatspot- need forum help
Fuel pump!
Pull fuel line off carb and pump fuel into a jug. It should pump strong and fill the jug quickly.
Old 03-04-2014, 01:53 PM   #3
DT1
DT1's Avatar
The first thing I'd check is the float level.
Could also be fuel filter or fuel pump.
DT1 is offline   Reply With Quote
Old 03-04-2014, 02:16 PM   #4
zellway
zellway's Avatar
Might help to know if this just started? I have seen a ignition system cut out like that. I had a HEI with a bad module that would idle around all day and soon as you got into it around 2k RPM it would cut out just like I had pulled the key.
Erik
My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626
1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647
RUST!? Thats just mother natures way of telling all of us.....MINE!!!!
zellway is offline   Reply With Quote
