03-04-2014, 11:31 AM | #1 |
Cab stand questions
I'm looking into making a cab stand that can be used to work on (welding and sandblasting) and paint the cab on. I would like to use this one on a few other projects down the road so I wanted a metal frame. I know I have seen a ton of cool one in different builds on the forum. I found some specs for the base. What I would like to know is if anyone that has made one would have done anything different. In talking with a friend he told me he would have liked it to be shorter and have locking casters and all the casters would swivel. Any one have any pic's they would like to share?
Attached is the pic I found with specs for the holes in the floor of the cab.
----------------------------------------------------------- Erik My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626 1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647 RUST!? Thats just mother natures way of telling all of us.....MINE!!!! |
03-04-2014, 02:07 PM | #2 |
Re: Cab stand questions
Found this caster. Looks like it would hold up for a long time.
http://www.grainger.com/product/Swiv...&cm_vc=IDPRRZ1
03-04-2014, 02:15 PM | #3 |
I cut up a wrecked (front frame horn bent) long box frame. I cut it just in front of the front cab mounts and just behind the trailing arm cross member. welded on some casters and welded a piece of random tubing between the frame rails to support the frame in the area of the front cab mounts. Works great. I can also easily pick up the cab with a forklift, because the trailing arm crossmember keeps the cab from hitting the forklift.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
03-04-2014, 02:18 PM | #4 | |
03-04-2014, 04:47 PM | #5 |
This is one that my son-in-law built for us from those same measurements. It has the Industrial size casters with locks and is extremely stable and maneuverable. He used some discarded 4" metal tubing from his company. I think you can get the casters at Tractor Supply or Harbor Freight if you have a store in your area. We haven't bolted the cab to it yet, but I am confident that this is the way to go. We will drill the mounting holes once we set the cab onto it to make sure it is a perfect fit.
I hope this helps. POP
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
03-05-2014, 09:10 AM | #6 | |
03-05-2014, 12:08 PM | #7 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Here you go... http://67-72chevytrucks.com/vboard/s...d.php?t=192185
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
03-05-2014, 12:29 PM | #8 |
That is great! I'm going to look into that! Thanks for the link!
