Old 03-04-2014, 04:36 PM   #1
Cnordy
Electrical issues,
Hi, I have a 72 blazer that is almost finished and looks great after a body and interior restoration , its all back together except for an electrical issue I have.
Here goes, I am installing a stereo and I was hooking up the memory and power from the ignition and all was working, then I un hooked it and ran my wires, hooked it back up and discovered no power to the stereo And then discovered no wipers and blower fan for the a/c-heater ,
Replaced two fusible links in the front, replaced the relay for the blower behind the glovebox, all fuses replaced and seems like the complete fuse block is dead..
What am I missing, everything worked then all of a sudden it don't,, any ideas out there.. I have a horn, lights work ,Truck starts right up, something simple I hope
Curt
Cnordy is offline   Reply With Quote
Old 03-04-2014, 05:17 PM   #2
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Re: Electrical issues,
Post this over in the electrical section - alot more attention over there.
http://67-72chevytrucks.com/vboard/f...splay.php?f=64
D.PASSMORE is offline   Reply With Quote
Old 03-04-2014, 05:31 PM   #3
Cnordy
Thanks for the tip,, hope someone knows what to look for
Old 03-06-2014, 05:16 PM   #4
DANTES JIMMY
DANTES JIMMY's Avatar
unbolt the fire wall bolts in the fuse block and seperate them i ll bet you have an issue between that connection in the fuse block from the inner and the outer fuse block
DANTES JIMMY is offline   Reply With Quote
Old 03-07-2014, 12:17 PM   #5
Cnordy
Thanks Dante,,
All is good now, was my ignition wire that fell out. then I had a few ground issues but all is working great now..
