Old 03-04-2014, 10:38 PM   #1
serrano2782
serrano2782's Avatar
Battery cables spark
Does anyone know why i get sparks when i connect the negative cable to a new battery? I replaced the negative cable with a new one.
serrano2782 is offline   Reply With Quote
Old 03-04-2014, 10:50 PM   #2
landy
Re: Battery cables spark
Are you connecting the negative cable to the negative post of the battery? Connecting it to the positive side of the battery will result in some big sparks!
If you've got the cables and posts connected with the correct polarity and there's still some sparking, there may be an electrical accessory that was left in the on position such as heater fan, etc. So when you the cable touches the battery post, the circuit for the accessory is completed.
landy is offline   Reply With Quote
Old 03-04-2014, 10:50 PM   #3
Longhorn 70
Longhorn 70's Avatar
How bad are the sparks? A small spark indicates a small current draw. If it looks like an arc welder, that's a different story.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 03-05-2014, 02:10 AM   #4
cool68
look on battery for + for positive large (usually red) cable to starter. small wire to junction. - negative (usually black) cable to ground bolt on motor.
cool68 is offline   Reply With Quote
Old 03-05-2014, 11:13 AM   #5
serrano2782
cool68 jumction?
I do have the positive to the positive and when I went to connect the negative that is connected to the alternator bracket its sparked when I touched the prong to the post
Old 03-05-2014, 12:43 PM   #6
cool68
Originally Posted by serrano2782 View Post
cool68 jumction?
search here for thread: Electrical Issues...Need Help!!! and in Electrical Section here for thread: Color Wiring Diagram FINISHED - both have info for you to help understand the correct wiring on your truck. have you ever had you battery tested to find out condition? a battery in poor condition (even a new one) can cause problems too.
Old 03-05-2014, 11:15 AM   #7
serrano2782
LANDY
Would this include head lights and winshield wipers?
Old 03-05-2014, 11:39 AM   #8
piecesparts
Parts and more parts
piecesparts's Avatar
If the spark is small, have you considered any thing like a aftermarket radio powering up the memory section of it, or an audio amp that is loading the power circuit on it? Just waiting for the turn on signal to power it up. How about a clock circuit in the truck?
Frank
piecesparts is offline   Reply With Quote
Old 03-05-2014, 11:43 AM   #9
67 chevelle
67 chevelle's Avatar
happens on almost all vehicles , unless you have an older one with no newer electrical devises installed
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 03-05-2014, 11:42 AM   #10
hamjet
hamjet's Avatar
Every thing should be turned off, including lights, ignition key. unless you have a clock, or modern radio which always has current running to it for the clock there should be no spark at all when touching the wire to the battery....
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 03-05-2014, 12:03 PM   #11
serrano2782
67 chevelle
Its a 1970 pick with no radio. Shell only
Old 03-05-2014, 01:07 PM   #12
serrano2782
COOL68
Just replaced the battery and cables.
Old 03-05-2014, 01:52 PM   #13
LONGHAIR
There is some kind of load on the system. It could be from lots of things, but the main thing here is safety. Quit disconnecting it from the battery end of the cable. Take it apart from the other end. The sparking will still happen, but it will be away from the battery itself. Sparks near a battery can blow the whole thing up in your face.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 03-05-2014, 04:46 PM   #14
hamjet
hamjet's Avatar
what about dome light, cargo light, anything like that, pull fuses, then check to see if you still have a load. if that stopped the sparking, add fuses one at a time till you find the culprit. Oh, and Longhairs right, at least wear safety glasses....
Thanks, Joe..
