Old 03-05-2014, 08:31 AM   #1
solidaxel
solidaxel's Avatar
Traction Control 5.3 2003
Is there a option for turning the traction control on or off in the tune process.
or is there even a traction control option?
At what point, RPM or speed, or throttle position can you set the down shift from 2nd to first, and from 3rd to second, or is this even possible?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 03-05-2014, 10:49 AM   #2
Hart_Rod
Hart_Rod's Avatar
Re: Traction Control 5.3 2003
I'm not sure if you have enough sensors to run the traction control. You can control the upshifts and downshifts. You can talk to your tuner about this, or even better, buy HPTuners or equivalent and then you can do it yourself.
Hart_Rod is offline   Reply With Quote
Old 03-05-2014, 02:25 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Like Hart said, you won't have real Trac. You'll have Tq management, but in a custom build it ends up hindering more than helping, and afaik it can't be turned off with just a button...it needs to be tuned out, as it pulls timing.
I think for real Trac you need ABS and a yaw sensor. In the vette's it can actually pulse the brake and reduce dbw throttle input. I'm not sure if there are wheel speed sensors, but it has some way of comparing wheel rotation to detect slip,
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-05-2014, 11:08 PM   #4
68c10airstream
68c10airstream's Avatar
Hi br3w city, i believe late models control wheel slip by comparing the driving axle to the non-driving wheels. I've noticed my late model front wheel drive went into a skid on a sweeping turn on black ice, the rear end started to slide out, it pulsed the brakes and reduced engine performance (drive by wire) and straightened me out before i could react. I believe the yaw sensor, and the slowing down of the rear tires engaged the traction control system.
68c10airstream is offline   Reply With Quote
Old 03-06-2014, 01:13 AM   #5
solidaxel
solidaxel's Avatar
O K, yes torque management, reduce timing to discourage wheel spin on instant acceleration something like that, not trac control
LS 3 4L70E
