Power Issue
Hey Guys,
I have a 1984 C10 Chevy. Here recently I have been having a lot of issues keeping a charge on her. Every time I turn on my headlights everything goes completely dead! My volt gauge drops all the way in the red. I have done the following recently; - I changed the bottom two bulbs in the rear brake lights. I have checked the sockets for corrosion and I have no corrosion of any kind. My truck has been restored a couple years back and the brake lights and setup were completely replaced. - I put a radio system in my truck (amp included). I had no problems before but maybe I disconnected a ground somewhere within the radio area. I would like to note that I have bought a new alternator (two of them to be exact). I am taking it this morning to be tested to see if that is the problem and once I get back I will provide an update on it. As for the battery, I bought it new last year so I dont see it being an issue but I am going to run a test on it as well. Also like to note that when I jump it off it will crank fine during the day. But when I turn those headlights on it over. It goes from doing fine straight dead. So can someone let me know what is going on? The two things I mentioned above are the two things I did recently that could have caused the issue (radio/replacing brake light bulbs). So what ground wires should I check? Could you also let me know where they are located so I know where to look. Thanks PS I will provide an update on the battery and alternator once I get back
1984 Chevrolet Silverado |
| Bookmarks |
