Old 03-05-2014, 03:35 PM   #1
man7sell
man7sell's Avatar
Loosing Coolant Suprise.
I have been loosing coolant rapidly. I know the heater core was bad but it had been bypassed. So got a new heater core and connected it up. Checked all my hoses and replaced a couple. All the rest are good.
Stilling loosing.
No leaks under the truck (Put a piece of white cardboard box under and ran the truck then let it sit over night...... couple of oil drips only.)
To drive the truck any distance (Like to a radiator shop to check the system) I had to replace the rotten, broken exhaust. Fitting a nice system on there, started the truck to see how it sounded, very nice but wait what's this???? Coolant coming out both tail pipes!!!!
What's the common denominator as both exhausts are separate, coming from separate heads.
The intake manifold. Darn, now I have to change that for an Edlebrock
man7sell is offline   Reply With Quote
Old 03-05-2014, 05:32 PM   #2
geezer#99
geezer#99's Avatar
Re: Loosing Coolant Suprise.
I hope that's not the new exhaust!
Water out of both pipes is just condensation.
What's all that red stuff you're using for gaskets on the intake?
Old 03-05-2014, 08:04 PM   #3
Jake Wade
Jake Wade's Avatar
Wow! No lack of RTV there for sure, Waaaaay too much.
Jake Wade is offline   Reply With Quote
Old 03-05-2014, 08:45 PM   #4
man7sell
man7sell's Avatar
Just the right amount the gaskets were photo'd before smoothing the RTV out. As for the back and front, instead of those leaky cork or rubber gaskets they give you, use a 1/4 bead along there, let it set up for a while but not fully, then sit the intake manifold down and torque it up, no more oil leaks front or back. Works great. Got it from this guy:
https://www.youtube.com/watch?v=1wVL0cjGmdI
Old 03-05-2014, 08:53 PM   #5
cleansquare
Weve always done the rtv thing front and back. Always works the forst time
cleansquare is offline   Reply With Quote
Old 03-05-2014, 09:21 PM   #6
Jake Wade
Jake Wade's Avatar
Yes, A bead of RTV front and back is the way to go, been doing it that way over 25 years.
Old 03-05-2014, 09:47 PM   #7
man7sell
man7sell's Avatar
Even says so on the Edelbrock installation instructions
Old 03-09-2014, 06:15 PM   #8
man7sell
man7sell's Avatar
Well no coolant out the tailpipes now, how ever I still loosing some, nowhere near as much but it's still going down. So no drips, no steam out the tail pipes, where is it going too?
Old 03-09-2014, 06:37 PM   #9
LONGHAIR
I am fine with the RTV on the front and back rails, been doing it for years......but having it smeared all over the gaskets? Not only is that waaay harder to remove, you have the potential for that getting into the engine when you do scrape it off.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 03-09-2014, 07:10 PM   #10
man7sell
man7sell's Avatar
You mean It won't last forever?
Old 03-09-2014, 09:04 PM   #11
mrolds88
They look like Felpro intake gaskets. I've never had to use gasket sealer on them. Just dab in the corners then lay on the gaskets and then build the bead front and back. And when I do use gasket sealer on a gasket (water pump/ tstat/ valve covers) you can read through it. Just enough to seal the surface.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 03-28-2014, 10:01 AM   #12
man7sell
man7sell's Avatar
so I found another source of coolant leakage. The heater return to the radiator has a crack on the fitting. It sprayed coolant up into the hood and then the fan sent it everywhere. So I removed the radiator and re-soldered the joint. Refilled the system and ran it. No leaking from the repair that's great...... so why is my leg getting wet standing at the front of the truck? Great, a rock has hit and punctured the radiator core. Now I have a new one on order.
