Old 03-05-2014, 05:33 PM   #1
fine 67
Junior Member
oem exhaust
does anybody know who making or sells all the pipes and muffler for my 72 blazer v8 4x4 i only want oem style thanks for the help mark
fine 67 is offline   Reply With Quote
Old 03-05-2014, 11:45 PM   #2
landy
Re: oem exhaust
Why not take it to a good muffler shop and use the original size exhaust pipe and stock muffler type? They can bend it anyway you want. Probably no vendors sell OEM exhaust pipe since it's readily available from muffler shops.
landy is offline   Reply With Quote
Old 03-06-2014, 03:54 PM   #3
fine 67
Junior Member
Re: oem exhaust
i did that with my crossover but that is all i had to work with .i need a compary that would have the pattern to bent my back to stock thanks
Old 03-07-2014, 08:50 PM   #4
Chulisohombre
Chulisohombre's Avatar
Re: oem exhaust
I'm guessing LMc truck or gmc Paul's might have it. I know summit sells a kit that is pretty close to oem also. As was said probably cheaper to go to a muffler shop and see what they can do for you.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
Old 03-08-2014, 12:09 PM   #5
turp mcspray
turp mcspray's Avatar
Re: oem exhaust
I think the only kits that are available, are for 2wd.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
