Gauge Cluster Bezel Questions
So, for the '73-'74 gauge bezels there is one part number. For the '75-'77 bezels there is another. And the '78-'80 bezels have another. To me, they all look the same. I heard after '75 the wiper switch was moved slightly. So will any '75-'80 bezel work even though there are two different part numbers? I'm in need of one for my '79 but all the eBay ads clump them all into the '73-'79 year range as compatable. I just want to make sure I get one that fits.
-Jonny B. 1979 Chevrolet K20 Scottsdale: GM350/SM465/NP208 1979 Jeep Cherokee Golden Eagle: AMC360/TH400/D20 1999 Dodge Ram 2500 Larime SLT: Cummins 5.9L 24v/47RE/NP241 Last edited by HeavyMetalThunder_81; 03-05-2014 at 07:46 PM. |
Re: Gauge Cluster Bezel Questions
73-74 bezels have a raised area around the headlight switch and a fairly narrow rectangular opening for the wiper switch.
75-77 bezels no longer have the raised area around the headlight switch and the hole is larger. The rectangular opening for the wiper switch is a bit wider too. 78-80 bezels have some styling changes. But I believe they kept the same headlight & wiper switch openings as the 75-77 bezels. So they should still interchange. The lower steering column covers are shaped a little bit different where they mate up to the bezel so you'll need to use one that matches the year range of the bezel. |
Hey, thanks! So, they should all interchange then?
-Jonny B. 1979 Chevrolet K20 Scottsdale: GM350/SM465/NP208 1979 Jeep Cherokee Golden Eagle: AMC360/TH400/D20 1999 Dodge Ram 2500 Larime SLT: Cummins 5.9L 24v/47RE/NP241 |
Slots go on anything!
The wiper switch is in a little different location on the 73-74 trucks as well. The 75-77 bezel requires you to move the wiper switch a little bit to clear the hole.
1974 Jimmy- 5.3/4L80e/NP241 |
That's what I thought. Good to know, thanks!
| Bookmarks |
