![]() Join Date: Sep 2013
Upper Radiator Hose # 454 w/serpentine belt?
I have a crate GM 454 Gen VI with the serpentine belt system in my 67' and I am hoping someone has "been there done that" and can give me a part number for a molded upper radiator hose that gives adequate clearance around the alternator and serpentine belt. What I have in there now works but has just slightly more than a gnat's azz of clearance. I think it is just a matter of time until something rubs.
Anyone? ![]()
1967 Shortbed Stepside - GM Crate 454HO 425HP/500 lb-ft, long tube Hedman ceramic coated headers, serpentine belt drive, Built 700R4, 12 bolt 3.42 with Eaton posi, 4 wheel disc brakes, OldAir A/C. 69' Corvette Lemans Blue. Painless Wiring Harness. Everything from the ground up is either new or rebuilt! |
Re: Upper Radiator Hose # 454 w/serpentine belt?
I had a similar issue. I couldn't find a good fitting hose because the angles were wrong. I got a aluminum thermostat housing that swiveled. It gave me a few more options on hoses. Here is an example http://www.jegs.com/i/Billet-Special...90220/10002/-1
I used a 45 degree swivel thermostat housing and the stock hose. Just takes a slight twist to get the hose to clear the belt.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
"Stock hose" for what application?
#5 | |
Good idea but I am trying to keep the underhood look somewhat "stock-ish" if you will and wanted to stay with a molded rubber hose.
That is why I came to the forum with the question...I have found lots of "chicken lips" in the search!
![]() Join Date: Mar 2003
Not sure, but what about a t-stat housing off of an LS engine say an '02 with the hose that wraps around behind. (originally the ac on an LS)
I'm not sure it's going to stay this way but this is what I put on mine.
Jason '70 C-10 short fleet 427BB TH400 (SOLD) '10 Ford F 350 '13 Ford RAPTOR 6.2 MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623 |
#12 | |
