Old 03-06-2014, 12:12 AM   #1
angertheloner
angertheloner's Avatar
Option Code question for transmission
I have a C20 with manual transmission. It was originally option code 1MM4. Does anyone know what transmission this is? I'm assuming it's a muncie, but I want to make sure.
Thanks!
There are 10 kinds of people in the world: those who understand binary and those who don't.
1985 C20 Scottsdale 350/SM465
1978 C10 Silverado Big 10 3 on the Tree (sold)
angertheloner is offline   Reply With Quote
Old 03-06-2014, 12:22 AM   #2
csdineley
csdineley's Avatar
Re: Option Code question for transmission
Most likely it'd be a sm465
csdineley is offline   Reply With Quote
Old 03-06-2014, 08:35 AM   #3
Keith Seymore
Keith Seymore's Avatar
Correct.
"MM4" is the "Merchandised" trans option code for "4 speed manual trans provisions". This is the code the dealer and/or customer would select, indicating a 4 speed manual transmission was desired. (By the way, the "1" is a dummy character; just a placeholder).
That code is then translated into the "non merchandised" code by the factory. Based on other powertrain considerations (model, series, engine, transmission availability and rear axle) the specific transmission type is selected.
In your case it was likely the M20 version which is the floor mounted 4 speed with the creeper gear.
Another example: if it was available and you had chosen "MM3" that would indicate a 3 speed manual trans. The other powertrain conditions would drive you into a Saginaw three speed, column shifted, with either a numerically low first gear (M62 = 2.85 first gear) or a higher first gear (M64 = 3.50 first gear).
I've attached the Powertrain chart for an '85 C20 (as found in the GM Heritage Center archives) so you can see what options were available in your specific case.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 03-06-2014, 12:32 PM   #4
angertheloner
Originally Posted by Keith Seymore View Post
Correct.
K
Thank you! This is awesome. I knew I had the 3.73 gear but this really clears up the rest.
