A day late and $1 short...
How did you smooth your firewall wire gutter?
I like the idea of a smooth firewall and I think I am going to use the Porterbuilt filler panels for the front side, but I also want to smooth the wire gutter at the top of the firewall. If you have done this, how did you do it? Post up some pics...
Here is the firewall of n2billet's latest build (SUPER SLICK!). He cut the top lip off and created a smooth 90° transition. I don't think I need to go to that extreme, so how did others do it?
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD Last edited by C10_ustacould; 03-06-2014 at 06:47 AM. |
Re: How did you smooth your firewall wire gutter?
Here is another great example by sgaylord, but I think I may use Porterbuilt hood hinges so I don't think this one will work, but the finished product looks AWESOME!
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
Those look great!
![]() Join Date: Oct 2009
I dont have pics, but I went to hardware store and purchased some mild metal strips, I believe 3/4 inch wide, that fit right in between the gap of the gutter. Then just welded in and bondo filled a little. These are the strips of metal like they have in the "metal working" section or "bar stock" maybe.
#5 | |
![]() Join Date: Apr 2007
Buck..i cut the "hump" across the middle of the gutter off and then welded in some 1/8 by 1 1/4" flatbar ....little filler....slick.....no finished pics yet...jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791 |
![]() Join Date: Aug 2004
No doubt, this modification really makes the firewall much nicer.
Here is how I approached this based on Sgaylord's process (actually he assisted me). You can check out more at my build thread.. I like the look of the cap at a 45deg as opposed to flat.
http://67-72chevytrucks.com/vboard/s...=362010&page=3 |
#9 | ||
A couple more Buck....finished in hi-build with Porters' pass side pieces and then with his hinges..they are trimmed a little a bottom with mine being flat...I like the 45* look too but may be tricky with P.B. hinges.....jim
