03-06-2014, 06:50 AM | #1 |
vent window rubber replace?
how much of a pain is it to replace the rubber?
I have the vent window asm out and off the truck and all new seals, it looks like I have to drill out the rivets to get the it apart so the rubber goes back in in 1 piece? |
03-06-2014, 07:50 AM | #2 |
Location: Sassafras. Victoria. The beautiful Mount Dandenong Ranges
Re: vent window rubber replace?
CLASSIC 1970 C20 WITH A RUMBLIN' V8. IT'S MY MID-LIFE CRISIS ONLY IT AIN'T A LITTLE RED SPORTS CAR OR A HARLEY! IF YOU'RE GUNNA SKATE ON THIN ICE, YOU MAY AS WELL TAP DANCE! |
03-06-2014, 08:31 AM | #3 |
It's not too hard. There are a couple of tutorials here on the board where guys walk you through the process, but the whole thing is pretty self-explanatory once you start digging into it.
I did mine a little while ago and used pop rivets and it all went together nicely. You'll be super happy to have the nice new rubber in once you get it all done. Good luck!
Curt 1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear |
03-07-2014, 06:41 AM | #4 |
I watched the first half, that's about what I figured
I planned on doing this tomorrow and don't have that style rivets, I do have some short grip range pop rivets Ill try every weekend I have ran across a dilemma and had to find more parts, all I was trying to do was change the worn out felt on the door glass, found the vent window frame rusted out when I went to put it back together, got a good used one with bad rubber, was going to take the 2 and make one, then discovered my rubber was bad too........ |
03-07-2014, 09:39 AM | #5 |
Carpe manana
You don't have to drill out the pivot rivet for the glass - easier to leave the factory rivet in place.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
03-07-2014, 09:56 AM | #6 |
Good one! Thanks!
