Old 03-06-2014, 10:51 AM   #1
Chevy3+3
Tailgate bands.....need some info
I have an 88 square and in search of the center tailgate band. My current tailgate was removed from a 78 C10. Its color matches my truck perfectly and is in great shape but would like to have the original tailgate trim.
So my question is...How does the trim piece attach? And will a blazer tailgate trim piece interchange with a pickup model tailgate?
Thanks for any replies
Chevy3+3 is offline   Reply With Quote
Old 03-06-2014, 12:57 PM   #2
bluex
bluex's Avatar
Re: Tailgate bands.....need some info
The trim pieces attach with screws through the gate. newer ones use a torx head an older are phillips.
The shape of the center of the gate changed slighty in 81. There are two types of trim for the 73-80 gates. A smaller one that goes in the center an a larger one that flattens it off. They attach the same way though.
You can use a blazer one but i believe it needs to be 73-80 as well to match your tailgate. You will have to flip the handle to the inside though since the blazer trim doesnt have the relief for the handle...
bluex is offline   Reply With Quote
Old 03-06-2014, 01:05 PM   #3
bluex
bluex's Avatar
Here are the two styles.
I hope that helps...
Old 03-06-2014, 04:47 PM   #4
Chevy3+3
So....if the tailgates changed slightly in 81 will the wide tailgate trim fit a 78' tailgate?
Old 03-06-2014, 06:04 PM   #5
TheBlueBomber
TheBlueBomber's Avatar
All the tailgates are the same. It's just a matter of mounting the trim piece.
Austin
1996 Chevrolet K1500 Silverado
1979 Chevrolet K10 Scottsdale - Carolina K10 -
My 4.8L Twin turbo build - Project Short Stroke -
Instagram - TheBlueBomber1996
TheBlueBomber is offline   Reply With Quote
Old 03-06-2014, 06:09 PM   #6
TheBlueBomber
As I was... misread the question. The tailgate band area did change.
Austin
Old 03-06-2014, 08:10 PM   #7
Chevy3+3
So the tailgates are the same but the recessed band area is different? So a wide panel trim wont fit on my 78 tailgate?
Old 03-06-2014, 09:06 PM   #8
1774btcrew
1774btcrew's Avatar
If I remember correctly, you should be able to get the 81-87 tailgate band to fit your earlier tailgate. I had a 81-87 tailgate on my 77 and the 77 wide band was about 1/2" too small. So the wider 81-87 band shouldn't have a problem fitting your tailgate.
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 03-07-2014, 10:55 AM   #9
Chevy3+3
Could you explain in what area the tailgate band was 1/2" to small? Length, width, etc.
Old 03-07-2014, 11:17 AM   #10
1774btcrew
1774btcrew's Avatar
The earlier bands are roughly 1/2" narrower from top to bottom.
Old 03-07-2014, 12:37 PM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
For reference. the wide band was Silverado trim, and the narrow band was Cheyenne trim.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
