Old 03-06-2014, 01:52 PM   #1
flashed
Rear End Gears
My 72 Chevy truck is a factory shortbed fleetside and originally was a 6 cylinder with turbo 350 transmission .When I got it ,it had been hotrodded and switched to a 350 V8 .It has been in the bodyshop for a frame off for almost 3 years now and is almost ready to come home but now has a new 350 crate motor in it .What rear gears were most likely in it from the factory and what would be the best for better gas mileage .I have not checked it to see what is currently in it ,it may the the original .
flashed is offline   Reply With Quote
Old 03-06-2014, 02:30 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: Rear End Gears
I assume C10, based on your transmission.
Could have been 3.73 (standard) with an optional 3.07 or 4.11.
Powertrain charts from the GM Heritage Center archives are attached, so that you can see for yourself.
Lower numerically is typically better for mileage...to a point.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 03-06-2014, 03:33 PM   #3
flashed
Re: Rear End Gears
Sorry ,it is a C10 ,thanks for the info .
