Old 03-06-2014, 02:48 PM   #1
mallen881
mudd truck axel swap
well I am going to make a mud slash trail truck and I was wanting to know if I run a sm465m tranny with a 205 t-case and put a dana 60 in rear and dana 44 in front what is the best gear ratio im looking to get and I will be raising it 25 inches so it gonna be tall so please help
mallen881 is offline   Reply With Quote
Old 03-07-2014, 03:23 AM   #2
swamp rat
swamp rat's Avatar
Re: mudd truck axel swap
Rotf................
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-07-2014, 08:50 AM   #3
Morgantown Mafia
Tire diameter plays the biggest role in determining what gear ratio. There are several other factors to consider as well. What size tire are you running?
Morgantown Mafia is offline   Reply With Quote
Old 03-07-2014, 01:16 PM   #4
flyingtim01
That front 44 will fight admirably, but won't live for very long with the 44"+ tires I'm assuming would be 'appropriate' for a truck with a 25 inch lift. I'm thinking of that moment when you're pegged at 4000rpm in the bog, spinning the tires, and then all of a sudden the front tires grab on relatively solid ground on the far side of the hole...
When you say 'mud truck' I think big lift, big tires, big HP - as in the kind of big tires and big HP that are probably pushing the limits of a Dana 60 while being thrashed through a bog. I think the bare minimum for a mud truck would be an Eaton or 14Bff in the back and a Dana 60 in the front.
1971 Chevy K20 350/SM465/NP205
flyingtim01 is offline   Reply With Quote
Old 03-07-2014, 08:46 PM   #5
john@thepier
john@thepier's Avatar
Aren't there companies making stronger u joints and axle shafts than what was stock in a 44? Most of the time when a axle shaft/u joint broke in my 44s was when I was pulling some other stuck guy out and I was in reverse pulling them from behind. Once I realized this I never did that anymore. I turned around and hooked from my rear.
john@thepier is offline   Reply With Quote
Old 03-08-2014, 01:27 AM   #6
willett
Another Day, Another Dollar
willett's Avatar
Yes there are, but the carrier is only going to take so much of a beating, not to mention tweaking the axle tubes under heavy load and a bad bump......
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
