Old member
Well I guess it's costing me a little since I used used parts. Took the truck over to transmission shop today to findout what was leaking. wasn't the pan gasket! The wire connector that houses all the wiring is leaking. They think the tailshaft bushing is bad also. You can push the drive shaft up and down.
New wiring, bushing going to cost about $400.00 for everything. They had to order the wiring connector so I have to take it back on top of that. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: Used parts
Damn that's rough. I'm having a few problems with my 4l80 as well, just haven't had the time (or weather) to really check it out. The pan gaskets aren't replaced every time you change fluid like old transmissions so I imagine you'd have to really bugger it up for it to leak.
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
Old member
I guess I'm shouldn't complain to bad. that pretty good I guess considering it all was a used unit. I just hope they can stop the leaking. I just wonder if you can tighten the connection up and stop it are put some kind of sealer on it.
Re: Used parts
I'm in the same spot. Bought it completely used and just replaced the u-joint, and changed fluid. It makes a pretty rough noise when shifting from drive to park, and seems to shift pretty damn hard.
Old member
Mine is shifting fine so far. I haven't noticed anything on the shifting. I just don't like leaks.
meowMEOWmeowMEOW
Re: Used parts
The side-connector leak is a known-4l80e problem. It really should be something we encourage people to service, but the truth is it rarely gets "announced". People chase down pan gasket leaks for months before looking to the connector. Because it leaks THROUGH the actual packing on the connector, the viscous fluid can make an electric circuit, and you get wacky stuff happening. Its the culprit for random trans codes or getting limp-moded if it goes out all together.
I'd tell you to do the harness yourself, but I guess if you gotta have the bearings done, it makes less sense.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#7 | |
Old member
![]() Quote:
Re: Used parts
one man's engine oil leak is another man's suspension component penetrating oil
-ancient truckproverb its the cycle of life bro |
Old member
Yea it's these money pits we call trucks that we love so!
