Old 07-24-2003, 10:26 AM   #1
Porkchop
Porkchop's Avatar
Is it worth it
I have my truck stripped down to nothing but the cab on the frame. I don't know if it would be worth it to fix the cab though. It needs rockers, cab corners, all the mounts, the floor near the front of the cab, firewall has a few holes, and the floor near the back around the gas tank bolt holes. I asked about oxy-acetylene welding a while ago and I have tried it many times but with no luck. So, what I am wondering is if this cab is even worth fixing. Would you guys even bother to fix it?
thanks for any info
brad
Porkchop is offline   Reply With Quote
Old 07-24-2003, 10:51 AM   #2
Randy70C-10
Randy70C-10's Avatar
Sounds like the same shape that my cab was in. I used a Lincoln SP-125 mig welder and replaced the rockers, cab corners, door pillars, parts of the floor, alot of the windshield frame and rear window frame, the door bottoms, and most of the upper firewall. It takes patience but I think that it was worth it. The way I look at it, I saved a cool truck from going to the scrap yard.
Randy70C-10 is offline   Reply With Quote
Old 07-24-2003, 10:55 AM   #3
Randy70C-10
Here it is!
Old 07-24-2003, 10:57 AM   #4
Porkchop
Porkchop's Avatar
Yeah, I wanted to say that I saved a truck from a scrap yard too. How much do those Lincoln welders usually go for? I have looked at a few tool rental places to rent a welder but I have not seen any. Do you know if it is common for a tool rental place to rent welders? Is the lincoln hard to use? Thanks for the help
brad
Old 07-24-2003, 11:21 AM   #5
Figment412
Originally posted by Randy70C-10
Here it is!
Are you planning on putting the fuel tank back into the cab?
Save your money and do it right the first time.
1968 GMC short bed
1972 Cab
74 SB Chevy running gear
Figment412 is offline   Reply With Quote
Old 07-24-2003, 12:16 PM   #6
VTKidder
Doesn't sound like it's in much worse shape than most of our trucks started out. I had to do both floors, inner and outer rocker, cab corners, all 4 cab mounts, then some random patchwork up where all the crap falls down through the cowl to the left and right 's*@t holding areas. I think mine was probably as bad as you could get and still save the darn thing. Definitely would have done things differently if I did it again. Wait....if?
VTKidder is offline   Reply With Quote
Old 07-24-2003, 12:21 PM   #7
Randy70C-10
Na, I still have to fill in the gas hole, I'll be using a fuel cell between the rails.
I've seen rental places rent welders, but as much work is required to restore a truck, it's cheaper to buy one. Mine was around $800 with the hoses, regulator, and gas bottle.
Old 07-24-2003, 03:19 PM   #8
Porkchop
Porkchop's Avatar
Yeesh, 800 bucks is a little more than I want to spend. That is why I was wondering about renting one. About how many hours do you guys have into your cabs? I originally wanted the truck to be completely done minus paint this summer... hhmmmm... well, I don't think that will happen. The only thing that I am worried about getting done now is the cab. It is holding me back from doing the frame and all the other body parts. I figure I could finish the cab and the frame this summer and then I could use the welders at school to do the minor fender and box work. So, do you guys think that if I set aside a weekend to work soley on the cab that I could get it done?
thanks for any advice
brad
Old 07-24-2003, 03:45 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
800 bucks will get you a damn nice cab.
However, you can't use the cab to fix everythign else that needs welded.
Old 07-24-2003, 03:47 PM   #10
1971Stepside
Almost Satisfied
1971Stepside's Avatar
My cab was in similiar shape, but I did not have any holes in the firewall area. Anyway, I have been working on mine since January. Now that is a couple hours at a time, but there is no way you will be able to rent a welder to do this job. It takes time! A lot of time.
I bought my Lincoln PRO135 Mig from Lowes for $400.00. It works great on the sheet metal. I have bought about $400 worth of replacement panels for the cab alone.
It would be much cheaper and less time consuming to buy a rust free cab out west and drive and get it, but then it just wouldn't be the same truck. Good luck
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
