Old 03-07-2014, 09:07 PM   #1
fastpace
Shift Linkage with Doug Thorley Headers
So we got the motor and everything in with the Doug Thorley DTE-324Y-C and we were planning on using something like the stock linkage but it doesn't look like there's any room. I know I saw some people suggesting the Lokar 625-ACA-1804 but I can't seem to find any pictures of it installed right now.
We're looking to connect the stock column to a 6L80 (which looks to have the same setup as the 4L60/4L80)
Any suggestions or pictures?
1972 C10 LWB Highlander Dark Olive/White - Work in progress 5.3/6L80e, Accuair e-level, Porterbuilt Stage 1 front and Stage 2 rear, Wilwood 14"F 13"R, Vintage Wheel Works V40 18x8/18x11, and more... Build Thread
fastpace is offline   Reply With Quote
Old 04-08-2014, 11:13 AM   #2
portworks
Re: Shift Linkage with Doug Thorley Headers
BUMP.. I am looking for the same info !
portworks is offline   Reply With Quote
Old 04-08-2014, 02:15 PM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Why not use a Locar cable??
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-08-2014, 04:12 PM   #4
portworks
Lokar said that it will not work with the 67 to 72 column, or the 4L60E electronic trans, with the black box on the side ?
Old 04-08-2014, 06:17 PM   #5
66LSx
66LSx's Avatar
I made my own for the 3 speed-on-the-tree for the 4L60e for $11 (3/8 UNF rod end and HRS rod)
5.3L 4L60e DTY 324 headers
OEM 4L60e shift arm vs. my fab'd one I made (note slot 'clocked' correctly in new one to position the downward motion of shift linkage correctly)
Park
1st
Heat and bend and fit... heat and bend and fit.... heat and bend and fit..... cut threads... viola (even with a shade tree mechanic press)
1966 C10 SWB Fleet
5.3L LM7 Vortec / 4L60e Swap
1966 C10 w/ 5.3L/4L60e Build Thread
2012 GMC Sierra 5.3L 4x4 CCSB
66LSx is offline   Reply With Quote
Old 04-11-2014, 02:24 PM   #6
Hart_Rod
Hart_Rod's Avatar
I used a Lokar shift setup (ACA -1800) on my 4L60E as well as on my 6L80. Pics are in my build thread.
Hart_Rod is offline   Reply With Quote
Old 04-11-2014, 08:36 PM   #7
portworks
I looked at it all again with the headers in place. I believe I can make a shift rod style assembly to work. This has been a looong frame off LS & BAGGED build that im ready to get on the road !!!!
Old 04-18-2014, 06:22 PM   #8
portworks
So with a few bends, adding a few inches and a hyme to the original shift rod,everything cleared. But the trans detent didnt match the column indicator.
So after making a new shift arm 1" longer and rotating the clocking position, it all matches perfect. Only with 1st gear alittle past/ lower than stock.
