Old 03-07-2014, 11:51 PM   #1
sixTsix
Aluminum slot wheel polishing
Calling on all of you old school fella's here. I just scored me a set of aluminum slots for my old bucket. So ill cut to the chase. These wheels, although in good shape, are going need some polishing love. So if you guys were in my spot what methods would you use for polishing out these bad boys? Surely one of you fellers have been here before and could shed some light on some methods for this.?
sixTsix is offline   Reply With Quote
Old 03-07-2014, 11:57 PM   #2
Lugnutz65
Lugnutz65's Avatar
Re: Aluminum slot wheel polishing
Depending on condition. I'd first use Mother's aluminum polish to remove the outer layer of dirt and oxidation. Then I'd start with 800 or 1000 grit sandpaper and sand the entire wheel by hand. I'd next go to finer grits until I got to 2500 grit or 3000 grit. Then I would use a buffing wheel with red rouge or other buffing compound and then finish by hand polishing again with Mother's polish.
Let's see your wheels.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 03-07-2014, 11:59 PM   #3
NEWFISHER
NEWFISHER's Avatar
It takes heat to polish aluminum. The best products I have found are NuVite polishes and a heavy high torque polisher, buffer etc
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 03-08-2014, 12:04 AM   #4
sixTsix
thanks for the rapid reply. Ill take some pics as soon as I get them ..hopefully next week!
So least you guys can see what I'm dealing with. until then, keep bringing on the advice, & keep on chiming in if you have comments or concerns
Old 03-08-2014, 12:26 AM   #5
Lugnutz65
Lugnutz65's Avatar
Why does it take heat to polish aluminum? Or are you saying that polishing with heat will give a better result?
Old 03-08-2014, 12:32 AM   #6
MisterC
MisterC's Avatar
Do a search for Slot Lovers Unite and yyou'll find great tips in that thread. I'd link it but my mobile skills are limited.
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 03-08-2014, 01:08 AM   #7
NEWFISHER
NEWFISHER's Avatar
Sorry, not heat like putting the piece in an oven then polishing, but laying into it hard with a buffer that has enough torque to deliver constant pressure without giving up. A red foam ball on the end of the housewifes cordless drill isn't going to "polish" aluminum. It will make the surface reflective. Chrome shops, wheel and trim polishers have huge electric motors mounted on stands or giant bench motors with whip heads and they have different heads or wheels of cotton and rouge compunds that they work from after sanding. Each step never contaminates the last. Each step has its own head/pad and its own rouge or polish.
GOD BLESS AMERICA!
Old 03-08-2014, 12:14 PM   #8
taclem
taclem's Avatar
Maybe mine weren't too bad, but I cleaned with SOS pads and then used Never Dull Metal Polish. It is as far as I have gone at this point. Lots of elbow grease required.
taclem is offline   Reply With Quote
