View Poll Results: What rearend do you have? Also state truck make, engine, and trans.
1/2 ton with Dana 44 rear 4 8.89%
1/2 ton with Corporate rear 20 44.44%
1/2 ton with semi float Dana 60 1 2.22%
3/4 ton with Eaton HO52 9 20.00%
3/4 ton with full float Dana 60 10 22.22%
Any, with custom rearend. 1 2.22%
Voters: 45. You may not vote on this poll
Old 07-24-2003, 01:08 PM   #1
1969 GMC
1969 GMC's Avatar
Rearend poll
i am curious about this, i have a theory that GMC's more frequently had dana rearends...
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 07-24-2003, 01:13 PM   #2
1969 GMC
1969 GMC's Avatar
forgot to mention, I have a GMC, 350/SM465, dana 60 FF rear, 4.11 original, now 3.73
1969 GMC K2500
1996 Honda Accord
Old 07-24-2003, 01:30 PM   #3
zyggy72
Can't kick the addiction!
I've got a 72 chevy custom camper, 350/th350, dana 60 FF, also w/4.11 gears.
zyggy72 is offline   Reply With Quote
Old 07-24-2003, 01:55 PM   #4
jayssunm
jayssunm's Avatar
My truck originally, Chevy 6 cyl. stepside, short bed. Not sure if the rear end is original although with all the rust and grime I am guessing it is.
Jay
67 Fleetside Shortie, small window, slip & slide tranny
Upgrades--small block, tilt column, disc 5 lug conversion (front and rear),
Future Projects--suburban gas tank under the bed, rear roll pan, better gas mileage (currently about 6-10 MPG)
jayssunm is offline   Reply With Quote
Old 07-24-2003, 02:25 PM   #5
72moneypit
72moneypit's Avatar
72 C20, 350/350, Dana 60 with 4.11's
Paul
72 Cheyenne Super Custom Camper
greenaz@hotmail.com
72moneypit is offline   Reply With Quote
Old 07-24-2003, 02:41 PM   #6
Figment412
68 C10, 350/350 14 bolt FF Corporate with 4.11 (from a 74 chevy)
Save your money and do it right the first time.
1968 GMC short bed
1972 Cab
74 SB Chevy running gear
Figment412 is offline   Reply With Quote
Old 07-24-2003, 03:08 PM   #7
Gene
Gene's Avatar
I dont know what mine is its an original equipment positraction axle in my 1971 Chevy 1/2 ton. 3:07 ratio and I do know that it has springs and clutches. Anyone able to expalin to me what mine is called?
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 07-24-2003, 03:46 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Is that the same as a 12 bolt?
Old 07-24-2003, 05:05 PM   #9
1969 GMC
1969 GMC's Avatar
yeah thanks...i couldnt for the life of me remember its name when i made this
1969 GMC K2500
1996 Honda Accord
Old 07-24-2003, 05:13 PM   #10
highboy_04
highboy_04's Avatar
i dont know what rear i have all i know is that is has 4.11 gears.
'67 c10 350/th350
highboy_04 is offline   Reply With Quote
Old 07-24-2003, 05:28 PM   #11
1969 GMC
1969 GMC's Avatar
is your truck 1/2, 3/4, or 1 ton?
1969 GMC K2500
1996 Honda Accord
Old 07-24-2003, 05:28 PM   #12
highboy_04
highboy_04's Avatar
3/4 ton
'67 c10 350/th350
Old 07-24-2003, 06:26 PM   #13
special70gmc
special70gmc's Avatar
70 c20 custom camper gmc its got a 4.10 dana 60..........-kyle
1986 c-10 swb 5/7 drop 20'' coys
1958 belair 2door
special70gmc is offline   Reply With Quote
Old 07-24-2003, 07:08 PM   #14
72longbed
72longbed's Avatar
Rear Poll (carefull)
73 0r 74 14 Bolt Full Floater Posi with 3.73 Gears. What do they call this rear??
72longbed is offline   Reply With Quote
Old 07-24-2003, 07:25 PM   #15
70 CST 4X4
Have A Nice Day!
70 CST 4X4's Avatar
1/2 ton chevy 4x4- factory posi- 12 bolt rear- sm465 ( going to put in th350 soon)
1970 CST K10 350/350/205
Short Bed - Fleetside
Tach-Tilt-A/C-Tow Hooks
Front & Rear Disc Brakes
Front & Rear Posi 3.73 Gears
30 Gallon Stainless Fuel Tank
SOLD 01/18 !!!!!
2007 2500 HD Classic Crew Cab LT2 4X4 Duramax LBZ
70 CST 4X4 is offline   Reply With Quote
Old 07-24-2003, 07:54 PM   #16
crazy longhorn
Fabricate till you "puke"
69 Longhorn, 12 bolt ,with eaton unit, & 4.10 gears(no,not stock ) crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 07-24-2003, 08:10 PM   #17
Figment412
Re: Rear Poll (carefull)
[QUOTE]Originally posted by 72longbed
73 0r 74 14 Bolt Full Floater Posi with 3.73 Gears. What do they call this rear?? [/QUOTE
I think it is refered to a Corporate. How many spiders do you have in the pumpkin?
1968 GMC short bed
1972 Cab
Old 07-24-2003, 08:32 PM   #18
67cst
i love summertime
67cst's Avatar
67 with a 12 bolt 3:08 open...327/th400
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 07-24-2003, 08:44 PM   #19
krazy_texan
krazy_texan's Avatar
71 3/4 ton 12 bolt not sure of gear ratio
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 07-24-2003, 09:30 PM   #20
72longbed
72longbed's Avatar
Figment412, I don't know how many spiders in that pumpkin. Each time the ring and pinion were changed I had a rear shop do the work.
Old 07-24-2003, 09:32 PM   #21
GMC71k20
3/4 ton GMC with an eaton
GMC71k20 is offline   Reply With Quote
Old 07-24-2003, 09:54 PM   #22
lukecp
Formerly yellow72custom
lukecp's Avatar
1/2 ton Chevy, whimpy 3.07 one-legger gears in a 12-bolt Coporate. Think it is starting to go out since it is now 1/4 of the way through wearing out 350 engine #3 .
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 07-24-2003, 09:56 PM   #23
Pumkin Truck
Thats just prime!
Pumkin Truck's Avatar
i have the infamous 12 bolt one legger
*69 GMC short bed stepside with a wimpy six that can barely pull itself.
*99 Chevrolet Camaro Z-28
1 Bad 5.7ltr LS1
Pumkin Truck is offline   Reply With Quote
Old 07-24-2003, 09:56 PM   #24
drink2mny
drink2mny's Avatar
72 super cheyenne 3/4 ton 2wd dana 60 full float/3.54 gears
Support The Board
drink2mny is offline   Reply With Quote
Old 07-24-2003, 10:03 PM   #25
heyjoe
3/4 ton with Eaton HO52 -- '67 Chevy; 250 6cyl; 3 speed manual
'67 C20 small window Fleetside - 250 inline 6 - 3 on the tree - heavy duty clutch, brakes, rear springs - 17.5 wheels w/bias ply tires - AM radio - heater.
heyjoe is offline   Reply With Quote
