03-08-2014, 08:58 AM | #1 |
ididit questions
im needing a new steering column, i have been looking at ididit but just wondering if their columns a direct bolt in, and pros and cons of the product.
currently my truck is manual steering but im slowly getting stuff together for power steering will the new column work with manual and power steering? link to the one im looking at getting http://www.ididitinc.com/retrofit-st...ruckFS_Retr-46
1968 chevy c10 lwb, 250 inline6, 4 speed, |
03-08-2014, 09:40 AM | #2 |
Re: ididit questions
Ididit makes a nice column as does Flaming River. Check summit or jegs, they will have it priced cheaper. Plus you can look on the board for a nice original column.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
03-08-2014, 10:15 AM | #3 |
Send kevsclassic a PM on here, he rebuilds and refurbishes factory columns , good price , great work you will not be disappointed
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
03-08-2014, 10:38 AM | #4 |
Roto Reuter thats the name...
I installed an Ididit column in my 69 C20. It's a very good product and direct replacement. I was very pleased. I originally had automatic on the column and wanted to go with a floor shift. I installed a chrome Ididit column and Lokar Nostalgia floor shifter. You would have to determine if you want to stick with stock OE look or go with something more custom. My C20 is a resto-mod and not stock, so that's what I was going for. Do some serious price searching online. Good luck.
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
03-08-2014, 10:39 AM | #5 |
Good info.
James B. 1967 Chevy Fleetside Shortbed 4X2 (Black & Beautiful) 1971 Chevy Fleetside Shortbed 4X4 (White & Rough) |
03-08-2014, 06:10 PM | #6 |
currently i have a non tilt and i would like the tilt feature. i did look around online and jegs has the column the cheapest i have found. does anyone have info on if i can use non power steering and later add power steering? or is it not a factor?
03-08-2014, 08:25 PM | #7 |
you need to dig around on this site for info about those "affordable columns" one day you will be driving along and then be sucking guard rail. I got a OEM refurbished Tilt from board member Kevsclassic on here, and it was professionally done with good quality parts.
I do believe Flaming River and Ididit are of premium quality but that is why you pay the premium price.
03-08-2014, 08:44 PM | #8 |
I put an Ididit column in my truck, I was very happy with it. Yes it was a direct replacement.
Jason '70 C-10 short fleet 427BB TH400 (SOLD) '10 Ford F 350 '13 Ford RAPTOR 6.2 MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623 |
03-08-2014, 09:32 PM | #9 |
Old member
The steering column shouldn't have any effect on weather you go power are not. The rag joint seperates the column from the sector which is where the lines hook up to assist you in steering.
I like the stock tilts myself.
03-09-2014, 08:35 AM | #10 |
bigmac i have read about the cheap columns that's why i am not looking at getting one of the cheap ones, and that's why i am trying to get info about the ididit column.
03-09-2014, 01:07 PM | #11 |
Either the Ididit or Flaming River columns work well. I used a stainless tilt Flaming River column in my truck and it does what it should and was a direct plug in to the existing harness.
03-09-2014, 01:31 PM | #12 | |
http://www.zigsstreetrods.com/Pages/columns.html
03-09-2014, 01:31 PM | #13 |
is the old tumbleweeds still open in Stillwater??
03-09-2014, 06:16 PM | #14 |
yeah but its not how it used to be.
03-09-2014, 07:42 PM | #15 |
Moderator
If you want "cheap" and "good" get a van tilt. They are original GM and bolt in with very little modification.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
03-09-2014, 09:29 PM | #16 |
ididit's are they way to go !!
03-10-2014, 08:02 AM | #17 |
Ididit column! Installed in about an hour or so. Be sure to by correct lens for your.
Tranny from them as well. |
03-10-2014, 08:24 AM | #18 |
what are you talking about?
03-10-2014, 09:06 AM | #19 |
and another question, what about my steering wheel? i have a grant 3 spoke and an adapter to fit it to the original column, will i be able to reuse that ?
03-10-2014, 09:12 AM | #20 |
Ididit is the one to got with Hands down.
1.Direct fit like you are asking about 2.USA made 100% 3.Gm internal parts 100% 4.Lifetime warranty 100% Best of all here at Scotts we have them in stock and we have the BEST the prices for sure If you want the best made column and great service and a great price.Let us know at (805)485-0382 Justin Last edited by Scottshotrods; 03-10-2014 at 09:12 AM. Reason: ad |
03-10-2014, 09:27 AM | #21 |
03-11-2014, 06:48 AM | #22 |
dirish i dont need a lens, i have a 4 speed
any info on the steering wheel?
03-12-2014, 07:00 AM | #23 |
ttt
