Active Member
![]() Join Date: Jun 2013
WTB 69-71 blazer filler neck and tank
I am looking to put a second tank in my 1970 c10 using 1969 to 1971 blazer parts.
Please send info on any of the parts you have to sell. Thanks Joe |
![]() Join Date: Nov 2001
Re: WTB 69-71 blazer filler neck and tank
Is the 1972 diffrent then. 69 - 71 and is there a diffrence with 2 wheel or 4 wheel drive.
Active Member
The 1972 has a solid steel filler neck all the way to tank, the others have a fill neck then a hose section and then steel below the bed towards tank. The gas cap is also a different size.
I am not sure if there is a difference between 2WD and 4 WD Thanks Joe |
Borrowed from other threads:
These are from 1972 Blazers. Hope this helps. Also available from another member are some nice kits at http://gmcpauls.com/fuel_tank_&_related.htm
1971 Bone Stock C10 project "Jake" 1997 Sierra SLT factory short bed "Silver Bullet" Last edited by Jake1971; 03-08-2014 at 03:59 PM. |
Active Member
Thanks for the pictures.
Is the pipe next to the fill neck in the blazer picture part of the fuel system? Joe |
![]() Join Date: Dec 2013
Location: Fort Mitchell, AL (out the back gate of Ft Benning)
Vent tube
SSG Walker Harris '72 Cheyenne Longbed '66 Panel '66 Short Stepside '65 Short Fleetside |
Active Member
Thank you
![]() Join Date: Nov 2009
I have a tank shipped from nm its a poly tank
Active Member
Thank you but I a looking for a metal tank.
Do you have any other Blazer fuel pieces like fill neck or lower filler pipe? Joe |
![]() Join Date: May 2011
I have a 71 setup with filler tube, bottom elbow, gasket w/ plate, and cover. I sandblasted the bottom elbow because it was pretty rusty and blew a hole thru it. I had a guy at work tig weld it with what he called silicone bronze wire and pressure tested it to 15 psi. I have a photo of the repair. The cover has the one corner rusted off I included a picture of the other side to compare. 100 shipped for everything. I have a tank also w/ sending unit that was on my blazer when I 4wheeled it so it has dents in the bottom but no holes. Let me know if interested and I will figure out a price. Sending unit worked when I pulled it out but that was 6 + years ago and two moves.
forgot pictures
Active Member
Hello
Yes interested in the items pictured and also the tank and does it have the tank straps? Do you have fuel vent tube? Thanks Joe |
#13 |
I have straps will they work for what you are doing? 100 dollars for the tank that will be 200 for everything plus shipping.
#14 |
Active Member
The factory tank is supposed to fit with the factory straps
is it possible to send picture Thanks Joe |
#15 |
Yep will send tomorrow
#16 |
Active Member
Do have vent tube?
#17 |
Sorry forgot to respond the first time you asked unfortunately I do not. I do not even have one for my build.
#18 |
I may have a friend that has one I will ask him tomorrow
#19 |
My friend does not have a vent tube attached pics of the gas tank, straps, and spacer between the tank and frame(I am guessing you will need this). Something else I could probably meet you in Winchester if that would work for you
#20 |
#21 |
Active Member
Winchester will work great
how is the filler neck on the tank, any damage? |
#22 |
No i can get better pictures if you like the edge might have a ding in it but nothing major. If you want to meet in Winchester I have a second tank I will bring them both and you can have you pick same condition. PM sent
