03-08-2014, 03:12 PM | #1 |
center link for disc brake conversion question
when doing the conversion on a 67 do you have to use a centerlink from a 72 half ton or fcan you use a three-quarter ton also?
1967custom |
03-08-2014, 06:09 PM | #2 |
Re: center link for disc brake conversion question
Any help would really be appreciated. Im at the yard now and found a 72 halfton with a good centrlink. I already have a 3/4 ton steering rack at home. So can I use the 3/4 ton centerlink at home or should I get this one?
1967custom |
03-08-2014, 06:13 PM | #3 |
67-72 parts collector,…
The centerlink, tie rods, spindles all have to match.
What year spindles are you using?
03-08-2014, 06:15 PM | #4 |
71-72 1/2-ton and 3/4-ton centerlinks are different.
Tie rods are also different.
03-08-2014, 07:19 PM | #5 |
Im using 71-72 half ton drop spindles
1967custom |
03-08-2014, 07:26 PM | #6 |
Is there a specific center link for disc and is it different for 72-73up?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
03-08-2014, 07:26 PM | #7 |
You will need the 1/2-ton 71-72 centerlink, inner and outer tie rods, upper and lower balljoints to "easily" make the 71-72 drop spindles work.
The use of 63-70 drop spindles,... would have made your life easier. They are a direct bolt on to your 67 steering and balljoints.
03-08-2014, 07:28 PM | #8 | |
It's all spelled out here,... but I don't think anyone reads this anymore. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Centerlink: Grouped by Differences: *60-62 *63-64 *65-70 *71-72 *73-87 With the introduction of CONVERSION drop spindles,... the 60-62 truck owners and the 63-70 truck owners now have their own disc brake spindle. THERE IS NO NEED TO USE 71-72 or 73-87 SPINDLES TO GET DISCS BRAKES.
03-08-2014, 07:32 PM | #9 |
I did not even know they had 63 to 70 drop spindles
1967custom |
03-08-2014, 07:33 PM | #10 |
They've been around for at least 10+ years.
(for about $229 almost everywhere) I try daily to get the word out. Not many seem to read this forum to learn and help. Most just log in and ask a question. Kinda sad.
