Fuel tank/pump
Guys need some help.
Here is the tank I have. The motor is a LS3 465 hp. Should I use a external pump? If so which one. I have something similar now on a 383 with aftermarket injection with no return line and no issues Or internal....I don't know anything about internal is there a kit that I cut the tank and mount? Not sure how the pump stands up in the tank. What about flow rate? ![]() Thanks in advance |
Old member
Yes you will have to cut the tank if you want a internal pump. Does this tank have the baffels? If not you may want to stick to the inline pump. You don't want to starve the internal pump for gas when low on fuel.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Addicted to Rust
![]() Join Date: Dec 2009
Re: Fuel tank/pump
You need one of these, Call Doc and he will send one out. Tell him Jay said to call. Just a hole saw cut away from an in tank pump.
http://docskustom.com/shop/viewitem.php?productid=486
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
#4 | |
Old member
![]() Quote:
![]() Join Date: Jun 2006
Re: Fuel tank/pump
The other internal option is this one: http://www.summitracing.com/search/b...s?autoview=SKU .
Its more money but its a known name brand that can support almost anything you can throw at it.
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
Re: Fuel tank/pump
thanks for the reply's. Some of this is nice but to rich for what I am doing
Enjoying left field
Re: Fuel tank/pump
There is an OEM option. When GM started using plastic tanks, they went with a fuel pump module so they wouldn't need baffles. Basically the pump sits in a cup that is held on the bottom by springs. They come in different heights depending on the depth of the tank. For example, I found one from an 02 Silverado. The module is 15" tall, but it compresses down to 12". And there are others that are shorter. You can find new modules on ebay for less than $100, or look in your local wrecking yards.
